Rear wiper removal 3rd gen
Old Jul 14, 2021 | 08:44 PM
sauceboss1989's Avatar
Going to wrap the cheap plastic chrome on my 2016 fit.
I did some research but everything I found was for the older gens. In their videos with a little wiggling they were able to remove the wiper.
I’ve already taken off the plastic cover and bolt but it does not seem to want to break free. Am I not wiggling it hard enough?
Na
Old Jul 15, 2021 | 10:52 AM
wasserball's Avatar
Na
I suspect there is a lot of friction that prevents the removal of the wiper arm from the splined shaft. There shouldn't be any locking mechanism besides the nut that you already removed. Use a little WD 40 and use a screwdriver to slowly lift the arm out. Of course you want to use a rag to prevent scratching the plastic chrome. I would put the wiper arm back on the windshield to reduce potential springing accidents.
Old Jul 15, 2021 | 11:55 AM
BMWguy22's Avatar
What are you planning on wrapping it with?
I'd like to do the same on my 16 Fit as well....
Old Jul 16, 2021 | 08:48 AM
JorbNorb's Avatar
Wiggle and pull.
Old Jul 24, 2021 | 07:39 PM
chameleon purple/green I think found on Amazon. Went with the more expensive one
Old Jul 24, 2021 | 07:40 PM
I tried wd40 with no luck. I’ll keep trying tho
Old Jul 27, 2021 | 10:35 PM
BMWguy22's Avatar
any luck?
I ordered the plasti dip kit and wanted to do this while doing the wheels.
Probably make a fun weekend project
Old Jul 27, 2021 | 10:46 PM
any luck?
I sprayed it twice and had no luck getting it off each time. Afraid to really tug on it. No wiggle room at all. Is yours a 3rd gen? Let me know how it goes
Old Jul 27, 2021 | 11:03 PM
wasserball's Avatar
stick a flat head screwdriver under the arm and wiggle it back and forth. Continue the same to the opposite side.
Wing On
May 25, 2025 02:59 PM
SilverEX15
15
Feb 22, 2022 08:27 AM
jt.wilson89
21
Nov 8, 2015 10:01 PM
justintime
Dec 2, 2013 01:05 PM
codenamezero
Mar 3, 2011 10:00 AM
