adding 12 volt accessory plug-- need some help.
Old Jun 8, 2008 | 09:26 PM
tbird911's Avatar
Hi Guys,
I just hopped on the group buy for the JDM center console with armrest. Now the fun part, I have a base MT. I know that this console will fit, but I need to either add an aux jack and 12 volt accessory plug or come up with a slick way to cover the two holes that I will have (as you know the base has neither the aux or accessory connections.
Anyone got part numbers for the two pieces and or DIY on the two? I have actually seen a DIY on the AUX audio jack-- what about the power?
ps. I'm a computer guy-- not really a car stero/electrical guy- so make it easy for me if you can.
Thanks
Tbird
Old Jun 9, 2008 | 05:35 PM
as far as power, you can get it from the front fuse box under the driver's
seat. use a add-a-circuit (up to 10A) and pull a wire to the new glove
box. as far as ground, get a volt meter and see if any of those bolts
you use to mount is connected to ground. if not, just wire it up to a
nut/bolt that is.
very easy.
Old Jun 9, 2008 | 06:34 PM
tbird911's Avatar
Don't laugh, but add-a circuit-- Thats something I can buy right? I'm going to have an alarm installed when I get the car-- maybe I'll just have them "pre-run" the power for me and when my console comes in, I'll just plug it in.
Tbird-
Anyone have part numbers for the AUX audio jack and AUX power jacks to fit the JDM console?
Old Jun 9, 2008 | 07:43 PM
yah, most autoshops have it. it's made by LittleFuse.
Old Jun 9, 2008 | 07:48 PM
looks like this:
Old Jun 9, 2008 | 08:02 PM
tbird911's Avatar
Thanks for the help . . .
Tbird
Old Jun 11, 2008 | 03:21 AM
wdb's Avatar
wdb
If you decide to hide the holes rather than fill them, there is black kitchen drawer liner material available that would do a pretty nice job + even keep things in the pocket from making so much noise. Check out your local home center.
Old Jun 11, 2008 | 07:32 AM
tbird911's Avatar
Great Idea
Old Jun 14, 2008 | 02:56 PM
secondspassed's Avatar
Am I the only one reading this thinking "Base Fits DO come with 12v Power outlets in the same spot as the sport and they also come with a place-holder piece that covers the *same* hole as the aux jack hole in the JDM console"?
Just take the pieces out of the existing console and move them.
Old Jun 14, 2008 | 03:07 PM
tbird911's Avatar
Nope you're right. I posted this the other day before I actually picked up the car. I'm good to go. Thanks
Tbird
bensenvill
Oct 1, 2015 07:16 AM
TrippKnightly
Aug 11, 2012 07:10 PM
smeister
Sep 7, 2007 03:50 PM
ac lerok
May 7, 2007 01:58 AM
yo_fitty
Aug 28, 2006 11:06 AM
