Independent foglight problem!!!!! please help!
Old Jul 14, 2008 | 06:57 PM
xonexlifex's Avatar
i just did the independent foglight mod by running the wire from the steering wheel to the one of the fuses in the fuse box with an add a circuit, for sum reason i woke up to go to work and my power steering, my mileage meter, and speedometer/mph gauge wasnt working at all, so when i got home i re connected everything the way it was before and even tried it on different fuses and whatever fuse i put it on it wont let something function right, im leaving it the way it was but i was wondering wny the hell it did this bec it scarred the crap out of me bec i thought i fried the comp or something. has anyone else had this problem? i didnt disconnect the battery when i did it and i have luminics foglight bulbs if that helps for an answer
Old Jul 14, 2008 | 09:41 PM
trancedsailor's Avatar
I'm sorry bro. This is why I haven't tried the mod yet. I was afraid that would happen to me. I fail at wiring/cutting/crimping/all that jazz. I hope someone can help you out though!
Old Jul 14, 2008 | 10:37 PM
Arisenfury's Avatar
Did you try putting it into a spot with an existing fuse or did you just stick it in an empty spot? Make sure you do the latter or check the fuse panel to see where you're sticking it. There should be enough empty spots under there to just plug it in, either that or you cut the wrong wire on the steering wheel column. Did you verify that the fogs were actually turning on independently?
Old Jul 14, 2008 | 11:17 PM
xonexlifex's Avatar
ya the fogs worked perfect, but everything else wasnt, ya i stuck it into the number 3 spot which is the ignition meter and it had a 10 amp fuse in there so i used the add a circuit and put the existing fuse in the add a circuit and pluged it in. the lights worked fine but everything else was messed up, maybe there is too much power from the fogs bec the fog fuse is a 20 amp fuse
Old Jul 15, 2008 | 12:34 AM
doctordoom's Avatar
Supervillain
eek, i hope everything works out for you.
Old Jul 15, 2008 | 12:41 AM
xonexlifex's Avatar
ya everythings ok now i put everything back to normal. im just wondering if i needed two 10 amp fuses with the add a circuit in the number 3 spot
Old Jul 15, 2008 | 08:26 AM
Arisenfury's Avatar
Don't even bother with an add-a-circuit. Just get one of those male connectors with the two prongs and stick it into an empty fuse slot.
Old Jul 15, 2008 | 06:24 PM
xonexlifex's Avatar
are you sure that would work? bec i dont want to try anything else that will mess anything else up
Old Jul 15, 2008 | 08:13 PM
Arisenfury's Avatar
That's the way I have it wired up, works fine. I'll take a picture of it in a bit if you'd like.
Old Jul 15, 2008 | 08:45 PM
xonexlifex's Avatar
nope no need to, i tried it again today and all i needed way two 10 amp fuses in the add a circuit for them to work, i put it in slot 24 which was empty and they worked perfect, no problems, plus i grounded the wire and they work with the highbeams now! yay!
fit_driver_mtl
May 5, 2021 06:20 PM
seth8288
Jun 27, 2017 07:14 AM
cnordt24
Oct 7, 2014 10:08 PM
Gabybeba
Jun 11, 2013 05:07 AM
stock0891
Feb 20, 2010 04:06 AM
