JDM Wiper Mod.
Old Jun 16, 2010 | 12:08 PM
willitfit's Avatar
JDM Wiper Mod.
Alot of people have been asking me about this.
JDM Wiper Mod.
This is one of my MOST fav. mods on my car, why? because before when i had the wiper horizontal all the dust would collect on the blade and when i would use it to wipe my window in the morning all it did was cause more dirtiness on my window leaving streaks of mud. (yes mud, cause of the morning dew+dust=muddy windows.) So now that it sits vertical, no dust and no mud. and its +2 style points :P
Anyways, lets get on to the DIY shall we?
DISCLAIMER: ONLY ATTEMPT THIS AT YOUR OWN RISK, HAVE ALL THE TOOLS NECESSARY TO DO THE JOB PROPERLY. ONLY ATTEMPT IF YOU ARE COMFORTABLE WITH DIY PROJECTS AND HAVE SOME SORT OF MECHANICAL EXPERIENCE.
**Read everything below before starting on this DIY**
tools needed are:
-Phillips screwdriver
-Flat head screwdriver
-10mm socket wrench.
-Gloves*
-Grease*
(*) optional
1. Remove the rear wiper cap and unbolt the rear wiper. (10mm socket.)
2. Remove the hatch panel.
(i dont have a hatch panel, took it off more than a year ago.)
3. Once you've taken off the rear panel. You'll see the wiper motor. Remove that by taking the 3 hex bolts off. (10mm socket.)
4. You'll see that next to the hex bolts are 4 screw, remove them.
5. Once removing that, you'll see a long rectangular pinion attached to a plastic gearing on one side and a metal pivot on the other.
6. Next, Right under the side attached to the plastic gearing is a small plastic pin, using a flat head screwdriver, break it off.
7. After breaking the plastic pin, remove the pinion and reposition the metal pivot down.
(It slides down)
8. Reposition the pinion in the NEW hole and relocated metal pivot.
9. Reinstall everything backwards.
10. When reinstalling the rear wiper blade, play around with it so you dont wipe your rear garnish.
Have fun and be safe.
Old Jun 16, 2010 | 12:16 PM
willitfit's Avatar
oh and FYI for the GE's its the same but you dont have to break anything, just reposition and reinstall.
Old Jun 16, 2010 | 12:23 PM
Krimson_Cardnal's Avatar
I like it - will do.
Old Jun 16, 2010 | 12:48 PM
hayden's Avatar
I was just admiring this car on carview a few minutes ago. Looks like people indeed are into this over there. I also see quite a few wiper deletes.
Old Jun 16, 2010 | 05:18 PM
score04w's Avatar
thank youuuuuuu, just finished doing this and i love it.
Old Jun 16, 2010 | 05:50 PM
zer0sk8ordie's Avatar
Nice diy! I want to do this..
Old Jun 18, 2010 | 06:46 PM
MNfit's Avatar
very nice DIY but what makes this "JDM" is that how the Fits come in Japan
Old Jun 18, 2010 | 07:06 PM
willitfit's Avatar
To tell you the truth. I really dont know, all I remember is when I 1st did this(back in 08) and the original DIY said "JDM wiper mod" some called it the "Odyssey wiper mod"
Old Jun 18, 2010 | 11:30 PM
I did mine earlier today.. Took 15-20 min
Old Jun 19, 2010 | 01:16 AM
crash001's Avatar
Gonna do this in a few good diy
Old Jun 19, 2010 | 04:36 AM
FitDEEZ's Avatar
did it to mine a while ago, love it
but my wiper wouldn't come off so i had to work around it , it sucked
Old Jun 21, 2010 | 12:06 PM
alvarospatchez's Avatar
Thanks for posting the DIY! I just did this. I've been wanting this for a little while now, but I wasn't sure what was involved. Simple 5 min mod that stands out a little.
Old Jun 23, 2010 | 10:20 AM
willitfit's Avatar
this should be stickied...
Old Jun 23, 2010 | 10:33 AM
^^^ditto^^^
Old Jun 23, 2010 | 03:25 PM
insane_one's Avatar
nice! easy and simple. not sure if i want to do this but x3 STICKY THIS!!
Old Jun 24, 2010 | 12:58 PM
krakhed's Avatar
ARGH DAMN IT
now i'm going to get yelled at again for doing something else....
sick mod. quick, clean and deceptive
Old Jun 24, 2010 | 01:17 PM
j's_fit's Avatar
I did this already for my Toyota Vitz now I think I will do this to mine GE8 too.....yeah!!! thx for the pix
Old Jun 28, 2010 | 03:12 PM
Black3sr's Avatar
I would like to do this as well but a couple of questions.
Remove hatch panel??? Are we talking about the black garnish panel underneath the wiper and not the interior hatch panel right? How is it removed?
Could someone explain the pin that has to be broken off? I do not see it in the pic above.
Thank you everyone.
Hayden what do you have under your Fit Badge? I have a 'Sport" one from WalMart
Old Jun 29, 2010 | 01:06 PM
PhishesSleeper's Avatar
Super simple mod that makes alot of difference. Did this to my BBP 09 yesterday and think its a great lil mod to help you find you car in the parking lot at the supermarket as well as clear the dirt and pollen off of the rear window.
Old Jun 29, 2010 | 01:56 PM
Thank you everyone.
No - it's the interior panel. As near as I can tell it "pops" off. I'm going out to have at it now. If I figure how not to break anything I'll post back.
I don't think you need to break the pin - 09 right?
K_C
