JDM Wiper Mod.
Old Oct 20, 2011 | 11:32 PM
  #121
2fstfru's Avatar
not only is this hella steezy, but it actually is more efficient in the cleaning of the back window. Nice DIY
Old Dec 3, 2011 | 05:47 PM
  #122
kcle730's Avatar
LOVE ITTTT
Old Dec 7, 2011 | 04:26 PM
  #123
f1tz1lla's Avatar
hi guys! new guy here in forum. i got honda fit 2012 sport. did anyone try this mod in 2012model?
Old Dec 7, 2011 | 05:35 PM
  #124
Krimson_Cardnal's Avatar
Welcome to the freakworld - post a pic then GO FOR IT a great first mod, but right behind Tint dakar ;-)
Old Jan 12, 2012 | 12:41 PM
  #125
Benbuss's Avatar
I just finished my rear wiper mod and have a few things I learned (that weren't in this thread) in the process and would like to share.
1. It's easier to remove the rear panel if you remove the rear hand hold first.
2. It's easier to "pop" the rear panel off if you start with the corner pieces closest to the rear window and work your way around.
3. The 2 tabs to the left of the hand hold are the ones that break.
4. This mod changes the wiper movement from Clockwise to CCW
5. Since the wiper moves CCW after the mod, you want to place the wiper arm in the desired resting position when finished (before turning wipers on).
6. The vertical resting positioning seen on most of the "after" pics (see Chris_music's pic on p.6 of thread) will result in end of the wiper motion being perfectly horizontal. This is the position I prefer and have seen in most of the pics.
7. The rear view isn't hurt at all with the wiper in modded position and the rear headrests installed.
Old Jan 13, 2012 | 10:11 AM
  #126
Benbuss's Avatar
BTW my car is an 08 Fit. These "lessons" may or may not apply to the newer Fit.
Old Jan 14, 2012 | 01:03 PM
  #127
ragingti's Avatar
Just did this, thanks for the info and tips. Hopefully this helps with the ice buildup after sitting overnight.
Old Feb 27, 2012 | 01:24 AM
  #128
kostar's Avatar
nice. will be working on this soon.... thanks all for the pics n info
Old Apr 13, 2012 | 08:35 PM
  #129
Virrdog's Avatar
Did this tonight.
Also a hard thread to search for with all the 3 letter words in the title.
Old Apr 14, 2012 | 01:56 PM
  #130
gavin-jarosz's Avatar
Cool mod, defintely makes our Fits stand out a little more.
Old Apr 16, 2012 | 05:10 PM
  #131
Virrdog's Avatar
One tip I figured out:
If you are having trouble getting the wiper arm off the motor stud, a 7/8 or 22mm crescent wrench can be used to help pull it off. You place one end of the open wrech on top of the stud (or the loosened nut) and the other end slides under the wiper's base. Angle it correctly and you can use the leverage from the stud to pull the wiper arm up off the post.
I can take a picture if that makes absolutely no sense...
Old Apr 16, 2012 | 05:30 PM
  #132
Virrdog - I've been tinkering with cars since mid-century and I've also struggled with pulling things off splined connections as well, so I would be most interested in seeing a pic of your technique.
K_C_
Old Apr 17, 2012 | 04:41 PM
  #133
Dwalbert320's Avatar
2012 Fit Sport . Read the post and ran outside to do this on my lunch time. It took me 12 mins...I love it!
Old May 17, 2012 | 03:54 PM
  #134
Virrdog's Avatar
Lightbulb
Finally had a chance to grab picture of what I was talking about when getting a stuck wiper off the post. And it's a good thing, I wanted to throw some anti-seize on the old rusty bolt & stud.
This is with the nut off. You use the stud itself as a leverage point to pull UP on the body of the wiper. So you rotate the wrench upwards so that the top stays put and movement comes up under the wiper arm:
This is an alternative depending on how the wrench wants to grip (or not grip) the stud and wiper arm, run the nut up to the top of the stud to make the gap smaller and/or give a larger area to press on:
Hope this makes sense.
...please ignore the hideously dirty paint. Not going to name names, but between my wife and I, someone just drives the car and tends not to wash it... but it's not me.
Old May 25, 2012 | 08:55 AM
  #135
Remould's Avatar
Thanks for the How-To.
I did the mod to my UKDM Jazz GD1 this lunchtime.
Looks cool and is practical too.
Old May 26, 2012 | 08:30 AM
  #136
Remould's Avatar
And here are a couple of pics...
Again, thanks for the How-To.
Steve.
Old Jun 9, 2012 | 07:54 PM
  #137
willitfit's Avatar
Steve.
man! i always loved that alabaster silver...
Old Jul 30, 2012 | 03:28 PM
  #138
Chad T's Avatar
oh and FYI for the GE's its the same but you dont have to break anything, just reposition and reinstall.
Glad I re-check the thread. Always thought this was a good idea. perfect day for it. It's beautiful here today. Doesn't even feel hot anymore right after I eat.
Old Jul 30, 2012 | 06:25 PM
  #139
Mine.
Old Jul 30, 2012 | 06:45 PM
  #140
LongGrain's Avatar
I did this yesterday. Didn't have many problems. the wiper practically jumped off at me when I took the nut off.
here are some concerns that I encountered. I'm going to put solutions here for people that might not know how to do these things, since some werent addressed.
1. Took me a few minutes to figure out how to take the handle out of the interior panel.
Solution: Use 2 flat heads to pry the 2 tabs downward and it will slide out. You must take this out to get the panel off from what I could tell.
2. I had trouble getting the connector for the wiper motor disconnected.
Solution: I didnt disconnect it... Instead I folded my rear seats down, closed the hatch and just sat inside for the duration of the mod.
3. The 4 screws holding down the backing plate for the motor were really tight on mine, I almost stripped them.
Solution: Put on your big boy panties and quit being a pussy, put some serious pressure on them. Also make damn sure you're using a phillips that is a good fit, something too big or too small will strip those screws out quick, then this quick mod will become a huge pain.
I mention these because I'm a mechanic by trade and have built numerous cars from the ground up in the past and present, and these few things still held me up. So I wanted to mention them for the people who are maybe not so mechanically inclined and might run into the same complications.
Other than that it went swimmingly. I really like it.
