Getting through the GD3's firewall?
Old Nov 27, 2010 | 12:10 PM
feddup's Avatar
I've looked for answers but haven't found them searching the forums. What's the easiest and most tasteful way to get a power wire through the GD3's firewall? I'd like to avoid voiding any warranties and HOPED to avoid just drilling a new hole. I've seen a few pictures where extensive cutting near to critical stuff was involved. I'm trying to minimize damage. Any help would be appreciated. I'm hoping to run a 4-8 gauge wire through to the battery.
Old Nov 27, 2010 | 01:46 PM
JDMchris.com's Avatar
I run THIS
theres a plug on the firewall where the main harness comes through. remove that grommit and run it through there. (passenger side)
Old Nov 27, 2010 | 02:36 PM
feddup's Avatar
side?
Which side do I attack it from, the engine compartment or under the dash? Does it push through or is cutting required? Thanks for the response. I just prefer a little knowledge before I dive in!
Old Nov 27, 2010 | 05:32 PM
I run THIS
I found it was easier from the inside of the car. U dont have to cut anything.
Old Nov 27, 2010 | 09:43 PM
feddup's Avatar
Thanks
Thanks for the info. I'm planning on a subwoofer in the passenger side rear corner so I guess I'll run the power wire along the passenger side door sills. Thanks again for the help. I'll get in there tomorrow and look for the grommet. I hate being on my back so at least help on where to start will save some pain (literally).
Old Nov 27, 2010 | 11:10 PM
Perrenoud Fit's Avatar
I drilled a hole in the knockout where the clutch would be (mine is an auto). Snap in grommet and all is well!!
Comes out right behind the battery, I ran a 4ga to my amp from there. GLW the install.
Mike
Old Nov 28, 2010 | 12:12 AM
feddup's Avatar
stick
mine's a manual, of which I'm quite fond, so that's not an option. Thanks for the input. Any other options would be appreciated!
Old Nov 29, 2010 | 10:16 PM
feddup's Avatar
blower removal?
Did you remove the blower? It seems to block access to everything. I see massive bundles of wires running behind it.
Old Nov 29, 2010 | 10:46 PM
Texas Coyote's Avatar
Sometimes all you can do is to get something done is to make a decision as to where you can drill a whole and wish for the best.... You know, like Haliburton did for British Petroleum.
Old Nov 30, 2010 | 12:50 AM
DiamondStarMonsters's Avatar
I'd laugh if it wasn't so sad.
If things are cramped down in the footwells, as they usually are, use an unfolded coathanger or some fishtape and push that sucker through the grommet (gently) then find the hanger in the engine bay, tape the wire to the hanger and pull it back through.
Old Nov 30, 2010 | 01:03 AM
I run THIS
I ran a amp on my beater fit, not the SC'd one.
Old Nov 30, 2010 | 02:28 AM
Fitting's Avatar
There's also one on the driver side that's easy to get to from inside the car. It's not visible from the engine bay since the strut tower hide it.
Old Dec 31, 2010 | 09:37 PM
feddup's Avatar
thanks
Thanks for the help. I installed the Basslink today. I thought getting through the firewall would be the hardest part. I got through in five minutes using the driver's side grommet. Wiring the rest and making everything look OEM took a lot longer. Thanks again!
Old Jan 2, 2011 | 11:57 AM
thorton0's Avatar
i used this spot yesterday for fog light wires. easiest place i could find
Old Jun 27, 2020 | 09:36 AM
Nima Ebrahimnejad's Avatar
Mike
100% SUPER EASY... I wasted hours trying to figure out the right way to go though the firewall.... drilling through the clutch pedal location (if you have an automatic) is perfect. Thanks for the help.
ck42
May 12, 2017 08:22 PM
Shravan S. Dwarka
Mar 19, 2017 07:25 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
12vltfrk
Sep 30, 2009 08:10 PM
krissnkev
Jun 6, 2008 04:18 PM
