Ask : oil cooler adapter
Old Dec 29, 2010 | 09:15 PM
ku8o's Avatar
guyz
need help
i bought a used oil cooler, comes with this item
i notice some part is missing which is rubber seal n inlet-outlet fitting naples
but these physicall looks made me curious is this really oil cooler adaptor ?
have any reference for this part would be greatly appreciated
thx before
Old Dec 29, 2010 | 09:35 PM
Texas Coyote's Avatar
You can use the seal from your present oil filter if it is the right size... Do you have any fittings for the hoses, and what are the 2 bolts that are in place on it for?
Old Dec 29, 2010 | 10:25 PM
ku8o's Avatar
yes , seal wouldn't be a problem
fittings not so hard to find
these two bolts i think its oil tap; so it has 4 cooling line;
still dont get it how to place these
i do have others brand of adaptor for comparation
the other side :
sides with seal
notice any difference ???
Old Dec 29, 2010 | 10:50 PM
JamesBizzle's Avatar
The blue one is an oil sandwich adaptor that you can use to screw sensors in to read oil temperature and pressure on a gauge mounted in the cabin.... The silver one on the other had is an oil cooler adaptor with a thermostat and this is what you want to properly run an oil cooler. The thermostat opens a trap door (that leads to the cooler) at a certain temperature to cool the oil. The reason you want a thermostat is so that you don’t have to wait for your car to warm up when it’s cold out…. Basically, the oil will only be cooled when it needs to be cooled.
Keep in mind that connecting the lines incorrectly can seriously damage your motor. Make sure you to connect the outlet fitting from the adaptor to the inlet fitting on the cooler, and the outlet fitting on the cooler to the inlet on the adaptor.
Old Dec 30, 2010 | 07:40 PM
ku8o's Avatar
i see so this is the same adaptor with two different purpose
the blue one for sensors such as oil temp n pressure
the silver one adaptor for oil cooler
one more question about the blue one
if i already had oil cooler adaptor n intend to use oil sandwich adaptor for sensors
how do put those two ; between filter oil
Old Dec 30, 2010 | 08:11 PM
I wouldn't recomend using both the adaports between the block and the filter. I could not find an oil cooler adaptor on the market that had both a thermostat and bungs for sensors so whatI did was take a Greddy Oil cooler adaptor and I tapped and drilled the two extra plugs in order to screw in my oil temp and press sensors onto the adaptor.
Here's the Greddy unit I bought: Trust GReddy Engine Oil Block Adapter Type E 57mm
Old Dec 30, 2010 | 08:17 PM
glowshift offers one with an two 1/8npt bungs for gauge sensors but it doesn't have a thermostat. Their's is much more cost effective but because it would constantly be runniing oil through the cooler, you would have to warm your car before you start driving.
Oil Cooler Sandwich Adapter - 20mm 1.5 Thread
**NOTE** You'll have to run about 1/2 - 3/4 of a quart of extra oil once you're running the oil cooler.
Old Dec 30, 2010 | 08:18 PM
$123.88, what kind of cooler and gauges are you using?
Old Dec 30, 2010 | 08:30 PM
I actually got mine for $85 but that was a one time special price from a friend of mines.
For oil, I'm running Greddy SM Integrate Oil pressure and Temperature guages.
I made a custom Oil cooler kit using a tranny cooler for the cooler unit.
Old Dec 30, 2010 | 08:48 PM
Hey, Thanks a lot, I was wondering why no one had used an A/T fluid filter before.. I could never see why one wouldn't work, they do the same job, from what Iv'e seen are cheaper and come in more sizes... Is it working well ? I will need a cooler before summer comes around again... It's crazy how much stuff I seem to need here lately.
Old Mar 13, 2011 | 11:55 AM
hkjazz's Avatar
Does anyone know which Greddy oil cooler fits into our Fit? Because there is a specific oil cooler from Greddy made for certain cars and no universal oil cooler. So just wondering which Honda oil cooler from Greddy would fit? Thanks
Press Fit
Mar 18, 2024 02:05 PM
robs
Aug 23, 2017 03:12 AM
Odie
28
Apr 4, 2013 01:43 PM
Daemione
Apr 9, 2009 11:47 AM
mozarwasagenius
Mar 31, 2009 12:54 PM
