07 fit blower motor questions
Old Jan 3, 2011 | 02:18 PM
bdk323's Avatar
Hello everyone well I think my blower motor is going bad its actually
intermittent right now but sometimes when i turn my fan on nothing works
then I move the fresh air to recirculation control back and forth some what hard the blower comes on and all fan settings work. I remember reading a while back someone saying if you can hear the dreaded helecopter noise coming from the fan its going bad . So one question would be is there a DIY for this I searched but could not find one. What are the part numbers for the parts I need to replace? Is it the blower and the transistors (I dont know if thats right I keep reading transistors or something needs to be replaced with the blower also) or can someone point me in the right direction I did a search and mostly GE8 come up with people saying take it in for warrenty repair. I'm an aircraft mechanic myself so I dont have a problem doing it just need some direction/help
Thanks Brad
Old Jan 3, 2011 | 11:36 PM
krakhed's Avatar
double check the filter, make sure nothing in there is hanging down interrupting the fan.
other than that, while you got the glove box open checking the filter, give a quick check to the 3 cords that control all that fan awesomeness.
you could have some stickiness/issues come up just because of age and whatnot (do they wear out?). i completely forget the hot/cold switch when i did my radio install and freaked out that all i could feel was heat and nothing would work.
after a day my brain reminded me "hey dumbass, you never hooked that one back up"
couldn't hurt.
Old Apr 23, 2013 | 12:12 AM
MonkeyMD's Avatar
I know this is an old post, but I am having the exact same issue.
I read on another thread that replacing the blower motor is simple, but would appreciate more details from somebody who had done it.
I have changed the cabin filter. Can I access the blower from the same place behind the Glove compartment.
alex.melvin
Mar 18, 2018 05:05 PM
Seanhan
Dec 6, 2016 06:10 AM
Spacecoast
Jun 4, 2013 12:59 AM
egvtec
Dec 5, 2012 10:42 AM
johnnyvirgil
Jul 10, 2011 02:09 PM
