Tuning ECU!
Old Oct 16, 2011 | 05:50 AM
alf74's Avatar
Tuning ECU!
I succeded in tuning it, eventually...
Old Oct 16, 2011 | 05:53 AM
alf74's Avatar
Once in boot mode you can read your ecu file....
But then you need a software to change your file.ori!!!
You have to know what to change, of course... and how to check the checksum finally!!!!
Old Oct 16, 2011 | 06:45 PM
apexanimal's Avatar
so you have this software?
do you have a list of pid's and their id's?
Old Oct 16, 2011 | 07:58 PM
Perrenoud Fit's Avatar
What did you change and what was the end results? Were you going for more HP or MPG? There has been alot of ppl tring to jail break this b.b.! +rep to ya!
Old Oct 16, 2011 | 08:01 PM
PS if ya really did something to make our econo boxes faster look out ....... your going to be busy re-programming.
Old Oct 16, 2011 | 09:17 PM
Bthasht's Avatar
Subscribed....
Old Oct 16, 2011 | 10:25 PM
Jamy's Avatar
I'm assuming this is GD only..
Old Oct 16, 2011 | 10:50 PM
SilverBullet's Avatar
I think Bosch ecu is for the Diesels. It would be cool if I was wrong. http://www.dimsport.it/admin/images/...2f35f634ec.pdf
Old Oct 17, 2011 | 03:17 AM
alf74's Avatar
I bought from a friend of mine a light version of the original software
My car is a Jazz idsi 1.3 year 2005 (L13A gasoline, not diesel!). I don't know what kind of ecu does Fit have, but I think that if it's a bosch you can reflash it in the same way!
Once you can reprogram your ecu you can do whatever you want.... ignition, fuel, closing egr and, the most important thing: adjust LAMBDA sensor...
Lambda is fundamental because otherwise the ecu will set all your changes to original values.... (even if you have bigger injectors or aem fuel ignition etc...)
I think that reprogram the ecu is the best and final solution if you want to modify your car! I thought it was impossible untill some months ago.... instead we can!! When I asked here in Italy for tuning my ecu everyone told me they had to unsolder the eprom inside the ecu to reflash it and they asked me about 350-400 euro for this kind of operation.
I succeded in doing it for about 150 euro instead.... with the possibility to adeguate ecu's parameters everytime I modify something other..
Old Oct 17, 2011 | 10:40 AM
FitStir's Avatar
*interesting*
Old Oct 17, 2011 | 10:00 PM
phenoyz's Avatar
Hope at last....will this work on a USDM GE?
Old Oct 17, 2011 | 11:50 PM
555sexydrive's Avatar
The GE ECUs, at least here in Japan and I am pretty sure in North America are not Bosch units. That is most likely an EU only ECU.
Old Oct 18, 2011 | 03:31 AM
alf74's Avatar
NEW Galletto 1260 ECU Remap Chip Flashing Cable EOBD OBD2/OBDII Flasher Tool | eBay
This is the cable you need to read the file...
Simply search for: NEW Galletto 1260 EOBD OBD2/OBDII
Old Oct 24, 2011 | 06:07 PM
jazzista's Avatar
Great alf, I'll mail you for more details.
Sadly this unit Bosch is NOT the same ecu used by GD3 Fit. BTW even the connectors do differ (so I have a boomslang harness around...).
HTH
Old Oct 24, 2011 | 06:23 PM
Jamy's Avatar
EU diesel only is what i'm thinking.
Old Oct 25, 2011 | 06:52 AM
jazzista's Avatar
This ECU is surely found on GD EDM petrol.
Old Jan 21, 2016 | 09:44 AM
trinisir's Avatar
OK.. but what software did you use to edit the .ori file?
ev8siv3
162
Nov 14, 2020 04:19 AM
davidteddiilin
Mar 26, 2012 05:54 PM
manuelgbn
Feb 16, 2011 02:56 PM
buttersandpaper
Feb 15, 2011 11:22 AM
Feinkosta
Feb 14, 2009 01:01 AM
