DIY: Innovative MM install/review on MT Trans GD3
Old Apr 20, 2012 | 04:57 PM
lcq4blackstar's Avatar
Thumbs down DIY: Innovative MM install/review on MT Trans GD3
Ok, let me first say a little about my experience with "Innovative" the company and these mounts. First I had to have these "special ordered" which was 2 weeks from when they would ship from Innovative because I ordered custom 75A urethane on all of them. No problem, but I would expect them to have been looked after before shipping out. When I got them I was on vacation out of state and had them delivered there. I gave them a quick look over and was very impressed with initial quality and even the effort they put into the box they ship in. Each motor mount was sealed in a plastic bag and had its own cradle in the box sized perfectly.
When I was home and got into the install I gave these new mounts a closer look and noticed that the shank that sits in the urethane bushing on the 2 drivers side mounts was a bit short on ether side by about 1/4".
I didn't worry about it to much because the design of these is so much different than the stock mounts. I had no issue with the rear most drivers side mount going in but made a note that it could be "crushed" from over tightening. On the top drivers side mount is where I ran into a problem because of the shank being to short or the urethane being molded to wide. There was just no possible way to get it to sit into the aluminum outer second part of the mount shown here:
To get the mount to fit I had to use an hobby knife to bevel both ends of the bushing shown here:
Again I had to make sure this bolt wasn't over tightened or it would be pulling the outer aluminum mount into the innovative mount and probably break the outer part.
On the original passenger side mount there is a stud that is part of it and the other stud is threaded into the engine block. I re-checked the box to see if I was missing some hardware but there was nothing included. I looked on the Innovative site and hardware is listed. Also you can see that I ran into fitment issues with this drivers side mount with out the hardware here:
I called them to see what the deal was with all these issues. I told the guy over the phone about all these problems and missing hardware and in an apologetic way said to bring them in. Mind you my car is sitting on jack stands stranded with 2 jacks supporting the engine and trans! They are just under 1 hour away from me and I would have hit traffic so I call back and they were closed 15min from when I first called! I left a voice mail with them and left e-mail explaining the issues. I have still not heard from them!!! I ended up getting hardware after work at True value here:
I decided to ditch the OEM upper bracket that is re-used on the innovative mount. factory mount was aluminum, this is a thick piece of steel so IMO its not needed. grade 8 12mm zinc coated bolts were used non-metric grade 8 yellow zinc washers were used as that was all that was available. 2 larger washers were used under the mount onto the engine that cant be seen.
Final thoughts: For the price Innovative charges for these I expect them to come complete or at the very least for them to make it right ASAP when someone has a problem! Between the no hardware and the short shank, These are sub-par quality for the price IMO. Bottom line f**k this company and their product because of there customer service! I'd beg anyone to not buy/support them but unfortunately they are the only option as far as I know to offer mounts for the GD3. I hope others receive a better product than I did that is at least complete...
For most of the install follow this:https://www.fitfreak.net/forums/fit-...nnovative.html
Only thing different for the MT is you will need no less than 2 Jacks to remove/install the rear mount.
First place the jacks here:
Remove the front and top trans mounts completely. Remove the front trans mount arm as it will stop against the frame when you jack the engine/trans up completely. The part is removed and you can see what I'm talking about here:
Take the 3 bolts out of the passenger side mount on the body as well but leave the 2 bolts/mount attached to the engine block. This will let you jack the motor up but it will still stop it from coming down to far as the mount will sit in the frame and stop it.
Jack up the motor/trans like shown here:
You will now have access to get the old mount out and the new wider/bigger one in! Once you get that mount in go ahead and bolt it up completely and run the bolt through it that attaches it to the trans.
With the rear mount in, move on to the passenger mount and get it into place. Start threading all bolts/nuts but leave them loose so you can move the engine trans around if needed to get the top drivers side in. Assemble the aluminum portion onto the new Innovative mount out of the car then install as one unit shown here: (3 bolts hold it to the trans and 3 bolts hold the new mount to the body)
Go ahead and tighten the passenger side mount down completely now. Last thing to do is re-install the OEM lower front drivers side mount and bracket back on. Do the bracket then the mount to it then the 2 bolts to the body. Install the battery, tray battery, air box and under tray.
You are done go drive!
Old Apr 22, 2012 | 10:47 AM
apexanimal's Avatar
jeez... that does sound like a pain...
innovative does nice stuff, but for the price i'm liking my filled mounts...
how do you like the nvh and feel of them?
Old Apr 22, 2012 | 09:35 PM
Same as the 80a stock ones I made. Did you make yours from my old how-to? The center shanks on both drivers side mounts broke loose from the urethane. I used the proper primer and everything, I'll try and put up some pic's of my old ones.
Old Apr 23, 2012 | 09:02 AM
apexanimal's Avatar
i went the cheap route and did window weld... i've only replaced the front trans mount so far, and once i'm driving the car full time, and not my wife, i'll replace the bottom rear one as well...
don't think i'm going to replace the side mounts... i'm largely staying stock, and the front and rear ones do most of the "pitch control" anyway...
that's creepy about the urethane not holding up... i would've thought they would've been good for a long time...
Old Apr 23, 2012 | 12:33 PM
Not so much that the urethane didn't hold up, more just the center shank didn't "bond" with it. Also if you remember the urethane was so runny I was left with half filled mounts so I had to fill the rest with the window weld. I don't like that window weld stuff, it never fully cured. I can still dig my finger nail into it on the old mounts. My front trans one is 100% window weld also.
Old Apr 24, 2012 | 09:39 AM
apexanimal's Avatar
i got an extra set of mounts, and i got busy, so my windowweld-filled mounts had over a month to dry... i think that's about the only way to do it unless you fill a little bit and let it cure... then put in some more and let it cure... etc... a pain for sure...
at least you finally got a set of mounts in that will hopefully stay nice for a while...
Old May 6, 2012 | 03:00 AM
Here are the 2 mounts that failed. It may be hard to see but the center shank broke loose on both.
The smooth side is the urethane and the bad looking side is where I had to fill the rest up with "window-weld".
Old May 6, 2012 | 10:32 AM
apexanimal's Avatar
that does look scary...
at least you have mounts that work now
Old May 6, 2012 | 01:47 PM
Texas Coyote's Avatar
I have dura mix and the gun to fill the mounts with .. Koi used this method on one or two of his mounts.. It drys and cures fast.. If I can get my brain and body syncronised for a couple of hours a day I'll be getting around to getting this and many more things done. I am debating the need for a weaponR Race header since I'm installing their intake manifold.
Old May 6, 2012 | 08:28 PM
I'm pretty sure thats the stuff I used. Are you just planning to fill the empty space in the factory mounts? Problem with that is the soft rubber and hard polyurethane wont play well together. Eventually the polyurethane will break up or debond. Make sure you get the proper primer to bond to rubbersnd rough up he rubber with a dremmel. If you really want to make em bulletproof get 2 large metal washers for ether side and drill 3 or 4 holes through the whole mount/washer stack, then put a nut and bolt through em. Also that dura mix is SUPER liquefied, it poured like water! so over tape the back side of the mount, just go crazy with the tape then put a rubber band around the tape/body of the mount and one around the tape/shank. Good luck!
FYI I've got a DIY on it somewhere on the forum.
Old May 6, 2012 | 08:31 PM
Just met up with da9rood yesterday, he also has the mounts and had the top drivers side mount issues but on his the steel shank was to wide and needed trimming as well as the poly.
Old May 6, 2012 | 11:36 PM
The Dura Mix drys and sets up an a few hours at most according to Koi being able to have all 3 mounts off with just the floor jack holding the car up is kind og worrying to me....
Old May 7, 2012 | 05:56 PM
Well you can't do anything with the passenger side mount so dont bother taking it out. The way it sits in the frame will let you jack the motor up but will not let it go down past stock height if its attached @ the engine. You only need a jack under the trans.for long term safety cut up some 4x4's (vertical) and lower the engine trans onto them.
Texas look up my DIY!
https://www.fitfreak.net/forums/fit-...on-mounts.html
Old Feb 18, 2013 | 09:22 AM
accordguyintake's Avatar
I really wanted innovative mounts, but this worries me a lot.
Old Apr 25, 2015 | 09:34 PM
Rollerboots666's Avatar
I know tho sis an old thread but I had even worse luck with my Innovative mounts I just bought. All the mounts didn't line up and there was no hardware. WTF! Completely agree for the price paid the fitment should be spot on.
Old May 17, 2015 | 09:43 PM
domoMKIV's Avatar
I'm a bit surprised after this amount of time the problems are still there. I guess innovative just doesn't give a damn.
Old May 18, 2015 | 12:49 AM
kylerwho's Avatar
spoon fed
all mine had holes drilled bigger than they should on the mounts themselves. I had to sand down the upper transmission mount poly.
I hoped for updated versions but I guess not.
evilchargerfan
Sep 28, 2019 06:28 PM
fit2bking
Jan 27, 2016 01:10 AM
KV43
Apr 26, 2015 07:24 PM
Matt91
Nov 7, 2013 11:58 AM
lcq4blackstar
Jul 13, 2011 06:04 PM
