Please Advise: GD3 Strut/Shock R/R
Old Jul 10, 2012 | 08:13 AM
der Mond's Avatar
The factory manual advises to use a spring compressor in the process of removing and replacing the front strut, whereas AllDataDIY.com describes a pretty simple and straightforward process of unbolting, removing and re-installing. I cannot find a strut removal thread; can anyone tell me which process to use or describe it in more detail?
Also, AllData recommends checking alignment after installation and the factory manual doesn't even mention it. Is it necessary? I'm just wanting to replace my OEM units with KYB's, no change in ride height
Old Jul 10, 2012 | 09:08 AM
avocado123's Avatar
FALCON PUNCH!!
This thread should help you out. Also, you do NOT need a spring compressor for this. One more thing, please don't post the same exact thread in multiple sections
Old Jul 11, 2012 | 08:41 PM
der Mond's Avatar
Thumbs up Thanks!
The thread seems to be the exact answer I needed, I am really grateful for your sharing it. I assume that since I would be replacing the shock but using the same spring, I would not need to have alignment adjusted afterwards.
I posed the question in the suspension thread and received no response. Sorry if I did something wrong; what is the issue with posting the same thread in several forums?
oiric2006@gmail.com
May 2, 2018 12:18 AM
Bruce Huff
Oct 7, 2015 02:06 PM
der Mond
Jul 17, 2012 11:11 PM
der Mond
Jul 11, 2012 09:20 PM
blue line
Mar 31, 2010 06:14 PM
