2007 honda fit ecu jet performance questions??
Old Sep 25, 2012 | 06:59 PM
lakia5524's Avatar
Talking 2007 honda fit ecu jet performance questions??
been wanting to know about the jet v force and jet performance programming. Has any one got any of these done want to get more acceleration. And dose any body know were the ecu is in the 07 fit ?
Old Sep 25, 2012 | 08:13 PM
Texas Coyote's Avatar
The ECU is in front of the front passenger door to the right of the glove compartment.
Old Sep 25, 2012 | 08:41 PM
SilverBullet's Avatar
Not sure that it adjusts fuel or timing. It looks like its a reader and Throttle controller built into one. The timing and fuel is constantly changing and it might slow it down to have a more controlled application to power. Unless parts are changed and the VE maps are changed it can only use what the factory puts into the ecu. A stock ecu can adapt to about 15 percent from stock form through correction features that in the ecu.
Old Sep 26, 2012 | 11:53 AM
Winding the little engine up to maximum revs with the throttle wide open every chance you get rather than driving like you want it to last forever will improve the way it runs... Putting some ultra light wheels like Enkei RPF1s or Kosei K4Rs on your car and not going crazy with heavy wide tires will make a noticeable difference in acceleration, braking and handling... Other than spending a small fortune in time and money to boost and tune the engine dropping a few pounds of rotating mass and unsprung weight has made more difference in improving performance than anything else for me.
Old Sep 26, 2012 | 12:57 PM
NIGHTHAWKSI's Avatar
that jet programmer will do nearly nothing for the fit.
save your money.
Old Oct 3, 2012 | 12:58 PM
lakia5524's Avatar
Thanks for the info any of you guys put difference exhaust header on ur fit if so what type I have been looking at the weapon r header and hks exhaust system.
Texas how do u like the Kraft werk sc been looking at those and spritex ones.
Old Oct 3, 2012 | 01:18 PM
TPColgett's Avatar
I agree with everyone else on this....
If you want snappier throttle response, throttle controllers are out there and I do like my BLitz unit.
I have a DC header on the car, and it was a subtle if at all noticeable change. IK-22 plugs and 91 octane were the most noticeable power change to date. Do searches on the Weapon R as I know there are multiple threads discussing them and fitment....
I am currently pursuing a tuning solution to comply with SCCA AutoX regs and to squeeze a bit more life out of my L15. I will put up a comprehensive post with my findings once I have every thing logged and sorted out
Trainman
Jul 19, 2012 12:56 PM
davidteddiilin
Mar 26, 2012 05:54 PM
manuelgbn
Feb 16, 2011 02:56 PM
buttersandpaper
Feb 15, 2011 11:22 AM
Feinkosta
Feb 14, 2009 01:01 AM
