Camber bolts and rear shims
Old Oct 14, 2012 | 05:56 AM
Jazzl13a's Avatar
Hi there.
I have seen a few different camber bolts around
- Eibach
- Moog
- SPC
Is anyone able to comment on which are the pick regarding quality and range of adjustment?
Same thing with rear shims. Which have the finest range of adjustment options and best grade of plastic.
- SPC
- EZ
- AcDelco
I need to loose 2mm of toe in on the Left Rear, the Right Rear is bang on.
Does that mean I will need a 0 degree on the right (to keep the track center in line) and 0º18´ on the left?
Has anyone got any real world experience with trying to convert the degree figure into mm on 14"'s
Lastly is this the most relevant DIY?
https://www.fitfreak.net/forums/fit-...er-mod-gd.html
All the best
Jason
Old Oct 14, 2012 | 10:03 AM
Hootie's Avatar
Hmm, haven't heard of Moog and I've heard (from a member that used to road race his Fit) that supposedly SPC's bolts are recommended for one time use only. Whether that "one time use" is per installation or alignment (which I doubt) is uncertain... I'd wait for someone to clearify that on the forum or e-mail the manufacture.
Haven't heard anything about Eibach's yet... Have heard H&R makes camber bolts as well. The strange thing is Eibach and H&R both produce lowering springs for the Fit that have identical characteristics in terms of drop and stiffness... SO if that theory is correct, then Eibach and H&R's camber bolts are basically the same.
Is 0 Degrees, 18 Minutes, and 0 seconds the specification for the rear toe on one side or is that how much that particular corner is off by?
Old Oct 14, 2012 | 03:27 PM
Jazzl13a's Avatar
Cheers Hootie.
Camber Bolts:
Seriously? That would indeed be quite useless.
Rear Shims
My alignment shop gives me the rather esoteric mm values for toe. The Left Rear is running 2.6mm toe in the other side is right where I want it at 0.3mm toe in. I wan't to bring the Left out to about the same as the Right. Hence trying to figure out what shims to use for ~2mm toe out.
According to the "Conversion chart: Toe in mm to degrees" in http://www.andysautosport.com/additi...00-ins_web.pdf on 14" 2mm = 0º18´ I'm interested to hear real world experience on this.
In theory there is no difference between theory and practice but in practice there is.
I'm guessing I should also use 0º shims on the Right side to keep the track even. Is this correct?
Thanks
Lil Blue
24
Jan 11, 2011 11:17 PM
flushge8
Hawaii Community
41
Feb 17, 2010 01:25 AM
chinkyy
Hawaii Community
Oct 17, 2009 01:44 PM
FITGD3
Apr 4, 2009 07:40 AM
Previc93
33
Dec 14, 2008 07:41 PM
