Which LSD
Old May 11, 2013 | 03:34 PM
Rabee's Avatar
Which LSD
I could not a find a Limited-slip differential for my 2013 Honda Fit
Do you guys have any ideas or suggestions?
Thnx
Old May 12, 2013 | 12:45 AM
kylerwho's Avatar
spoon fed
J's racing might still have a few but I was just informed that the fit line of lsd are discontinued. Unless Im mistaken the ge8 lsd will work.
Old May 12, 2013 | 11:35 AM
fujisawa's Avatar
I didn't know an LSD was even available for the L series trans .. I thought only the K had room for it ..
Old May 12, 2013 | 06:17 PM
13fit's Avatar
They really dont take up much extra room. Go look at a few pictures on the old D series lineup, seeing as they are the closest honda motor in size
Old May 12, 2013 | 06:18 PM
13fit's Avatar
09-13 honda fit EQUALS GE8
chassis code
Old May 12, 2013 | 10:04 PM
FormulaJDM's Avatar
Quaife makes a pretty good one.
Welcome to QuaifeLSD.com - Quaife LSD Importer
Old May 12, 2013 | 10:46 PM
TPColgett's Avatar
What about M Factory? .... also OP, why do you want to put in an LSD? What other supporting mods will you have? On an otherwise stock car with an LSD...... maybe better accel if you turn off the traction control
Old May 14, 2013 | 11:30 PM
Rabee's Avatar
I am doing the following mods next week:
1) Enkei rpf1 15X7 wheels with Dunlop Direzza zII tires 205/50-15
2) Swift Springs
3) Progress rear sway bar
4) SPC front camber bolts
5) Alignment to get -1.5 front camber and zero toes all four
6) Brakes brakes brakes, tire rack does not list any of Hawk brakes pads
do you guys know if the ones from 2007 models ( Hawk HPS or so) would fit on 2013 model??
So to answer your question regarding why I was asking about LSD...I am just thinking that LSD would improve cornering performance!? May be not the case in Honda Fit?!
may be unnecessary or overkill modification for the fit...I am not sure.
Thnx
Old May 14, 2013 | 11:36 PM
Holy crud, that car sounds FUN.
Old May 15, 2013 | 12:08 AM
Previc93's Avatar
The Lsd Will Help With Exit Speed And AlsoIf U Get A 2 Way Then It Helps With Braking Problem With That Is It Also Makes It Understeer A Ton. I WoUld Just Get A One Way.
M Factory Makes Good Stuff.
Old May 15, 2013 | 12:47 AM
Rabee's Avatar
mFactory ones don't fit 2013, they are for GD models
Old May 15, 2013 | 08:56 AM
linnboi's Avatar
cusco got some ?
Old May 15, 2013 | 09:15 AM
Rabee's Avatar
I think lsd is overkill, instead I removed the rear seat yesterday, 7 bolts out in less than 10 min! Lol
Old May 15, 2013 | 09:36 AM
mkane's Avatar
Limited slip necessary w/117hp? While autocrossing when we have a spinning wheel more times than not the air pressures to high.
Old May 15, 2013 | 01:55 PM
TPColgett's Avatar
Exactly.
Car will be WELL setup with your list of mods, but take that money from the LSD and spend it on a good helmet and either a driving school or a few seasons of AutoX and a track day or two.
I have near the exact setup going on my GF's 2012 which will be doing both daily and regular AutoX use.
What is your planed use for the Fit?
That is the ticket! Keep doing the "free" weight reduction and you will see the most gains. Look up the "Biggest Loser Fit Edition" thread on here for more ideas.
Old May 15, 2013 | 02:03 PM
Rabee's Avatar
TPColgett,
Thnx for the input.
This car is my daily driver, I love driving, I am like a kid going to theme park when I get in almost any manual transmission car
I actually use my Mustang Boss 302 for all the HPDE & autoX
No serious plans to take my Fit to HPDE , however I might do some occasional autoX
Old May 15, 2013 | 02:44 PM
TPColgett's Avatar
TPColgett,
Thnx for the input.
I know a bit about AutoX
Boss 302? What class do you run it in? A stock? Guessing ESP if your having fun....
The Fit is actually a GREAT AutoX weapon! It "fit's" best into Street Touring FWD class, where you can run up to a 15x7.5 rim and 225mm tires... You would have to put the rear seat back in to be class legal though Still, most bolt on's are legal (Intake, exhaust, bucket seats, springs/coil overs, camber bolts.) Give it a shot and I bet you will be surprised!
Old May 15, 2013 | 03:30 PM
Rabee's Avatar
What brake pads r u guys using for 2013 Fit?
Old May 15, 2013 | 04:06 PM
TPColgett's Avatar
On her 2012 we have not changed a thing. Honestly, at least for AutoX the OE pads and system really aren't that bad. With the Fit's weight and less than 100hp at the wheel you shouldn't be braking much anyways
I ran 75K+ and countless events before going to HP+ pads in my 2008 GD. Even then I only did that because I got a deal on them and want to be able to attend a few track days this year.
Old May 15, 2013 | 04:26 PM
FitStir's Avatar
Damn.... was looking forward to a possible LSD install on a GE, and review.
TPC... HP+ > HPS ?
