Which LSD
Old Jun 5, 2013 | 02:40 PM
  #161
TPColgett's Avatar
Haha, I can't sell them as the 7" ones were borrowed... If I end up like my AutoX friends, I will have a garage full of alternate spring setups in no time
Old Jun 5, 2013 | 02:42 PM
  #162
Wafulz's Avatar
ahh ok for sure
wish i can keep alot of my stuff but no garage lol i use my nabors storage in his back yard as one he been triping lately tho
Old Jun 5, 2013 | 09:24 PM
  #163
Rabee's Avatar
Are you enjoying your new setup a little too much?
What is your are your tire specs and tire pressure? Sorry if you said it before and I missed it. If your pressure is too low and sidewalls too tall and you're doing a bit more hooning on corners your sidewalls are probably rolling over.
I wear my tires more on the outside consistently but I throw my car around on/offramps a lot.
-1.8 - -2 is fine, you should just max it out like I said before. I'd also check to make sure your bolts didn't come loose and move or something.
I run around 33-34 PSI cold all four
205/50-15
Old Jun 6, 2013 | 08:27 AM
  #164
Rabee's Avatar
At belle tire getting -1.9 front and DEAD ZERO toe angle lol
Old Jun 6, 2013 | 10:25 AM
  #165
Rabee's Avatar
My impressions, car turns in better, steering response is quicker, tail a little happier than I thought, will auto cross and tell you more
Old Jun 6, 2013 | 11:54 AM
  #166
Wafulz's Avatar
hahah so my spot said we cant be always doing ur alignments alot so i said F them they gave me my refund back and going to place were a friend of mines takes his nsx gotta pay a lil more but hey Owell
so im pending my 2.0
Old Jun 6, 2013 | 01:06 PM
  #167
TPColgett's Avatar
Sorry Wafulz, Try to make friends with a "Race Alignment" place, they May be $$$ but they do the BEST work!
Rebee, Now it sounds like your having fun! Try to get us pics or video if you can!!! And as always, HAVE FUN. If your AutoX place is using standard SCCA Solo classing, your fit will be in Street Touring FWD (STF.) Just show up early and try to get in as many course walks as possible! Good luck!
Old Jun 6, 2013 | 01:14 PM
  #168
Wafulz's Avatar
yea im going to that place my freinds goes to witch is a race spot and he knws them
yup he told me before to go but i did not wanna spend the extra 60 bucks lol well i guess i will now no more YOLO alignments for me hehe
Old Jun 7, 2013 | 07:26 AM
  #169
Rabee's Avatar
How wide of a tire you can go with swift spring only?
without rubbing
Old Jun 7, 2013 | 09:31 AM
  #170
mkane's Avatar
From what I gather 215's on a 6.5" rim with an off-set around 45mm with some neg. camber up front.
Old Jun 7, 2013 | 11:29 AM
  #171
TPColgett's Avatar
The 15x7 RPF 1's you have COULD fit up to a 225, but I would not. A 225 really needs a 7.5-8" wide rim to be happy.
Offset is the next issue, but if it is higher that 30 you should be OK.
The 205 ZII's you referenced should be an AWESOME fit onto that wheel package...
What are you looking for from a wider tire? Some brands run different as well, for example my 205/50R15 BFR Rival's are about the same size as my 225/45R15 Hankook RS3's
Old Jun 8, 2013 | 09:17 PM
  #172
Wafulz's Avatar
impexmotorsports
9651 Valley Blvd
Rosemead‎ California‎ 91770
United States
Best spot ever quick service 2.3 camber. 0 toe
Old Jun 8, 2013 | 11:34 PM
  #173
Rabee's Avatar
Tire pressure for tomorrow autocross?
High 30s cold?
Front and rear differences?
Old Jun 8, 2013 | 11:49 PM
  #174
mkane's Avatar
35f/38-40r
Old Jun 8, 2013 | 11:55 PM
  #175
Rabee's Avatar
Cold or hot?
Old Jun 9, 2013 | 11:10 AM
  #176
mkane's Avatar
Those would be a hot temp. And it's really dependant on the tires you use and driving style. Some have a stiff sidewall, some not so stiff.
Old Jun 9, 2013 | 04:56 PM
  #177
Rabee's Avatar
Done with the autocross:
The car handles miles better than before!
The fastest lap I had was 43.45 seconds.
The understeer is still there, but at a higher limit, could not oversteer the car no matter what I did lol
I still insist that this car needs better brakes.
There were any Vipers out there, including Ralph Gilles ( Chrysler SRT CEO) with his 2013 Viper GTS!!
I took a picture with him and told " build us something like FRS/BRZ" he said " with more power" lol
He ran low 38s
It was a fun day, many vipers ( although it was Alfa Romero club), but my little Fit was the fastest among all other Vipers lol except Ralph's one, you think I am joking, I know you do, but I am not!
I am a novice driver but this little sucker with some decent mods can do wonders on a tight track, it was very tight.
I will try to check the website to see if I was right about the other Vipers and my time, because my conclusion was based on what I could hear when they announced times lol
I hope I am not lying
Old Jun 9, 2013 | 05:05 PM
  #178
Rabee's Avatar
A stock Subaru STI ran 40.05 second, this opened unhealed wounds
Old Jun 9, 2013 | 09:44 PM
  #179
mkane's Avatar
Tight tracks bring out the Fits weakness, no power. Fast flowing tracks are a preference.
Old Jun 9, 2013 | 09:49 PM
  #180
13fit's Avatar
If the suby driver was experienced, thats actually not bad to be only 3 seconds behind, given the fits power.
drop some more weight and invest in a lighter wheel and tire combo, and you might be able to smoke that suby
