***Official GD Parts/Weight List***
Old Jan 6, 2014 | 11:35 PM
devmail's Avatar
List the weights of OEM GD parts here! I'll add them to this first post. I've included all weights which were spread out in this thread: https://www.fitfreak.net/forums/fit-...ht-thread.html Thanks to the original posters for these values.
I've included pounds and grams since we have international members as well. The additions were done using the grams values. My weights will be for a 2007 Canadian Honda Fit LX 5 spd.
I've included headings to sum up the weight a vehicle could lose when these parts were removed. For aftermarket parts such as a lightweight battery, the difference between it and stock were calculated and included in these totals. When we add these we get 534.67 lbs (242525 g) weight reduction (most of interior removed, lighter wheels/tires, flywheel, battery, stock intake and exhaust but no muffler, Summit G2100 driver's seat). Keep in mind, this will be a race trim only.
Engine Bay/Exhaust with substituted parts and no muffler (keep splashguard) 85.74 lbs (38899 g)
A/C condenser, compressor, lines, bolts, brackets, idler pulley, r134a: 23.46 lbs (10645 g)
Air intake box assembly and air filter: 4.53 lbs (2053 g)
Airbox bracket: 0.49 lbs (224 g)
Brackets (wiring harness, fuel rail): 1.22 lbs (554 g)
EGR: 1.93 lbs (874 g)
Upper Rad hose bracket: 0.17 lbs (76 g)
Alternator Pulley 0.49 lbs (220 g)
-UR Alt pulley 0.15 lbs (66 g) (154 g weight savings)
Axle U-bracket on engine: 1.21 lbs (551 g)
Battery: 22 lbs (9979 g)
-Ballistic Ev0 2 8 cell battery, terminals and insulation: 2 lbs (907 g) (9072 g weight savings)
Crank Pulley 4.82 lbs (2185 g)
-UR Pulley 0.75 lbs (342 g) (1843 weight savings)
Engine firewall insulation: 0.65 lbs (297 g)
Engine Valve Cover + bolts: 0.49 lbs (220 g)
Exhaust
- Axle back Muffler, bolts, springs and heat shield: 11.53 (5231 g) 17.63 lbs (8000 g)
- Mid-pipe
- Secondary cat
- all other heat shields: 2.41 lbs (1094 g)
Exhaust Manifold Heat shield + bolts: 1.27 lbs (580 g)
Flywheel: 17 lbs (7711 g)
-Fidanza lightweight flywheel: 7.5 lbs (3402 g) (4309 g weight savings)
Stock Mounts:
-upper transmission, rear engine mount, and side passenger mount with upper aluminum bracket: 14.1lbs (6395 g)
- Innovative Mounts save 7.0 lbs (3175 g)
Spash Guard ~1.98 lbs (900 g) (I would leave this one on)
Exterior not including taillight 31.32 lbs (14207 g)
antenna: 0.06 lbs (28 g)
bumper rear: 6.48 lbs (2940 g)
bumper support rear: ~15 lbs (6804 g)
jack plate below spare tire well and bolts - 2.81 lbs (1275 g)
hood
-black insulating mat with clips: 0.80 lbs (365 g)
splash guards (4) with screws: 1.42 lbs (643 g)
tailights: 4.36 lbs (1976 g)
wipers front combined: 2.20 lbs (996 g)
wiper assembly Rear: 2.36 lbs (1070 g)
washer pump Rear: 0.19 lbs (86 g)
Interior 212.42 lbs (96353 g) so far...
-A/C evaporator core, interior lines, brackets, bolts: 3.36 lbs (1524 g)
-A-beam trims (front): 1.46 lbs (660 g)
-airbag + bolts (driver): 2.76 lbs (1250 g)
-airbag module: 1.01 lbs (460 g)
-airbags -curtains 15.43 lbs (7000 g)
-passenger 7.72 lbs (3500 g)
-sides 4.63 (2100 g)
-center console trim: 2.59 lbs (1175 g)
-ceiling: 2.36 lbs (1072 g)
-ceiling white long plastic brackets: 0.5 lbs (226 g)
-ceiling handles above doors and bolts: 0.92 lbs (416 g)
-ceiling rear seat belt trim 2 pieces: 0.35 lbs (159 g)
-carpet with grey under material already removed: 8.57 lbs (3889 g)
-drivers door interior trim, switches and door handle: 4.61 lbs (2094 g)
-drivers door plastic liner/tar: 102 g
-fuse panel/coin tray: 0.46 lbs (207 g)
-driver's access panel: 0.46 lbs (208 g)
-drivers center pillar lower trim: 1.18 lbs (535 g)
-drivers kick panel: 0.26 lbs (117 g)
-drivers front door sill: 0.22 lbs (98 g)
-drivers rubber/foam floor padding: 2.20 lbs (1000 g) *wet so weighs less normally
-firewall mat rubber/foam removed so far, still more to go: 10.49 lbs (4759 g)
-floor mats winter all: 10.75 lbs (4877 g)
-glove compartment with manuals: 6.583 lbs (2986 g)
-hatch 4 floor cargo net hooks: 0.43 lbs (195 g)
-hatch door panel - 3.07 lbs (1394 g)
-hatch rear lower latch panel - 0.83 lbs (375 g)
-hatch 2 large lower side panels: 6.28 lbs (2850 g)
-hatch 2 small upper side panels: 2.20 lbs (1000 g)
-hatch gutted metal only: 3 lbs (1360 g)
-heater blower, duct, brackets: 5.97 lbs (2710 g)
-jack, wrench, tow hook, mount bracket: 4.91 lbs (2227 g)
-passengers door interior trim, switches and door handle: 4.63 lbs (2100 g)
-passengers door plastic liner/tar: 102 g
-passenger seat 4 piece rail attachment covers: 0.31 lbs (141 g)
-passenger seat 4 rail attachment bolts: 0.25 lbs (114 g)
-passenger center pillar lower trim: 1.13 lbs (512 g)
-passenger door sill trim: 0.21 lbs (94 g)
-passenger kick panel: 0.19 lbs (87 g)
-passenger rubber/foam floor padding: 1.96 lbs (887 g)
-passenger access panel: 0.54 lbs (243 g)
-rear door interior trims both: 8.35 lbs (3786 g)
-rear seat 2 lower step panels: 0.58 lbs (265 g)
-rear seat upper brackets: 0.93 lbs (420 g)
-rear window 2 triangular garnish: (72 g)
-rear under carpet material: 1.54 lbs (700 g)
Sound Deadening Tar 8.36 lbs so far (3790 g)
-drivers floor panel: 0.68 lbs (308 g)
-driver's under seat and rear passenger floor panel: 0.82 lbs (373 g) so far...last panel, almost finished
-rear driver's side strut: 0.46 lbs (207 g)
-rear passenger side hatch floor section: 0.36 lbs (165 g)
-rear passenger strut: 0.33 lbs (151 g)
-spare tire well: 0.73 lbs (333 g)
-rear drivers side vertical floor panel 0.24 lbs (109 g)
-rear passenger side vertical floor panel 0.26 lbs (119 g)
-front passenger floor and rear passenger floor sound deadening panels: 3.84 lbs (1744 g)
spare tire cover: 7.76 lbs (3520 g)
spare tire: 21 lbs (9525 g)
speakers driver and passenger: 0.87 lbs (402 g)
speakers 2 rear: 0.87 lbs (402 g)
stereo/heater controls: 6.26 lbs (2840 g)
OEM steering wheel minus airbag + wire reel: 3.45 lbs (1564 g)
-RJ Max Ultra Light 13" steering wheel + 5 bolt adapter + MOMO hub adapter + horn button #4920: 2.91 lbs (1320 g) saves 0.54 lbs (245 g)
steering wheel column cover: 0.13 lbs (60 g)
sun visor drivers: 0.88 lbs (401 g)
sun visor passenger: 0.56 lbs (252 g)
Seats and Belts with G2100 drivers seat: 159.02 lbs (72130 g)
Seat Driver: 43.5 lbs (19731 g)
*Summit G2100 Seat (no cover) with custom brackets: 19.0 lbs (8618 g), a savings of 23.5 lbs (10659 g)
Seat belts rear all + bolts: 10.67 lbs (4842 g)
Seat belt passenger side with upper trim: 4.65 lbs (2110 g)
Seat Passenger: 51.5 lbs (23360 g) approximately, may be more
Seat Rear Passenger: 27 lbs (12247 g)
Seat Rear Driver: 40 lbs (18144 g)
Seat Rear lower mount brackets and bolts: 1.69 lbs (768 g)
Wheels & Suspension running VX wheels/tires 30.57 lbs (13866 g)
OEM calipers (pair) shaved to fit 13" wheels: 18.41 lbs
Wilwood DPHA calipers pair: 9.84 lbs
-Weight saved: 8.57 lbs
OEM tire sport: 19 lbs (8618 g)
OEM wheel 15" sport alloys: 17 lbs (7700 g)144
Springs Combined 13.94 lbs (6322 g)
-Front 3.75 lbs (1702 g) ea
-Rear 3.21 lbs (1492 g) ea
T1R S coil springs combined 18.98 lbs (8611 g) = 911 g weight gain
-Rear 5.04 lbs (2287 g)
-Front 4.46 lbs (2023 g)
Old Jan 12, 2014 | 10:38 PM
devmail's Avatar
Updated with the driver's side airbag, oem honda splash guards and rear hatch trim. Tried to get the rear wiper motor out but the wiper arm was stuck onto the motor...probably due to the chilly weather.
Old Jan 12, 2014 | 10:54 PM
Katsumoto's Avatar
Are you gutting your Fit or is as parts fail and get replaced or upgrade?
Old Jan 12, 2014 | 11:03 PM
devmail's Avatar
Well I'm seeing how much can be removed for track days. It's also my daily driver but I have no plans on driving it gutted...just race trim occasionally for the 1/4 mile track. My mods when I can afford them are intake/header/test pipe, exhaust removed (track only) and hopefully some 20" baby slicks if I can find them.
Old Jan 13, 2014 | 04:56 PM
Katsumoto's Avatar
Ah, I still have a 95% stock Fit.
I wouldn't mind taking my back seats out, it's just the 1 time I need them they wouldn't be in the car.
Old Jan 13, 2014 | 06:59 PM
devmail's Avatar
I hear ya, mines 100% stock right now and i always have passengers. I do have some hx wheels, 5 mm trak+ spacers waiting to go on when I can afford tires. Oh and the Ultraguage is in there too. As far as performance mods I plan on a header, test pipe and intake. Stock exhaust for now as it will be removed at the track a couple times a year. :-) Now the plan is to document the weight of everything that can be removed, I think 200 lbs is pretty easy but from there it's gonna be tough while still being able to put it back into daily driver mode.
Old Jan 13, 2014 | 11:01 PM
devmail's Avatar
Added the hatch interior mouldings, hooks, misc. I'm going to be fixing the leaks in the car which was my original intention for stripping it out. But I did go for a short drive and there is a great improvement in acceleration with everything removed from the rear seats on back. Tomorrow I'll try to get more stuff added to the list.
Old Jan 14, 2014 | 08:24 PM
devmail's Avatar
Added lots of trim, winter floor mats, and I also removed half of the under dash firewall matting due to it soaking up water and causing not only a stink but surface rust under the pedal area. Luckily it's not rotted through!
Old Jan 14, 2014 | 10:31 PM
devmail's Avatar
The glove box is surprisingly heavy. Added that and summed up the seats and belts to reach a total of 179 lbs! Also the interior trim is adding up to be more than I expected...race trim only.
Old Jan 17, 2014 | 10:09 AM
devmail's Avatar
Added the carpeting and tailight assembly. Forgot to weigh the rear bumper while I had it off, doh.
Old Jan 18, 2014 | 09:03 PM
devmail's Avatar
Updated the driver's interior door trim and door handles while attempting to fix leaks.
Old Jan 19, 2014 | 10:23 PM
devmail's Avatar
Stock speakers in the front weigh 201 g each.
Old Jan 20, 2014 | 11:35 PM
devmail's Avatar
Looks like 250 lbs weight reduction is possible with removing all interior trim but keeping the dash and roof liner! Add a lightweight battery, wheels, flywheel and exhaust and 300 lbs off is achievable.
Old Jan 21, 2014 | 02:29 AM
Texas Coyote's Avatar
Concentrate on reducing rotating mass. Lighter wheels and tires are going to do more to improve acceleration than anything short of forced induction and dyno tune.
Old Jan 21, 2014 | 07:10 AM
Jodele's Avatar
I still like the whole idea of this thread....
Old Jan 21, 2014 | 07:28 AM
devmail's Avatar
Texas Coyote, I totally agree! I have some HX wheels (11.75 lbs) waiting for tires to go on. Would love to get some Enkei RPF1s in 14" tho my budget is low.
Old Jan 21, 2014 | 01:43 PM
devmail's Avatar
The 14" Kosei K1 TS look good too at 9.3 lbs each and cheaper than rpf1.
Old Jan 22, 2014 | 03:06 AM
I think the Kosei wheels are great for the price.. I have a set of 16" K4Rs with 205 50 16" tires for everyday use and 15" Enkei RPF1s I'll be fitting 195 50 15s for when I feel like baiting local kids at signal lights or on back roads.. Old age is taking its toll on my wrenching ability but when I do get all of the new stuff on it and it's properly tuned I'm going to have a hard time behaving myself..
Old Jan 22, 2014 | 07:50 AM
devmail's Avatar
LOL, any plans on tracking the car? I'd like to get to the 1/4 mile at least once a year.
Old Jan 22, 2014 | 09:01 AM
I enjoy driving stealthy little cars that are fast but draw little attention from cops or the unwary that think they can intimidate me by staying on my back bumper at 80 MPG.. Most of the time I just poke around until I have an urge to go fast.. If I was to race, I'd have to work on it more and I am getting too old to do much of that anymore.. I have about $1500 in parts I still need to install and I will surely need a clutch upgrade after I do that. I've had this Fit since July 2006 and only have 41000 miles on it.. It's more of a toy than transportation.. I ride a Kawasaki 1500 Vulcan Classic sidecar rig more than I drive a car lately.
