Fit 2008 Struts
Old Oct 7, 2015 | 06:10 AM
Bruce Huff's Avatar
Thumbs up Fit 2008 Struts
I started removing the left front strut, I have everything but the top off but I don't understand how it comes apart. The strut bolt coming through the spring tower has a hex slot and a 17mm nut. Is it safe to remove that nut? or will the spring decompress?
Good advice will be appreciated and followed.
Thanks a Lot
Old Oct 7, 2015 | 02:06 PM
GolNat's Avatar
The spring is under tension so a spring compressor should be used to prevent it from de compressing.
According to this DIY there is not a lot of tension so you don't need a compressor.
https://www.fitfreak.net/forums/fit-...-08-gd3-8.html
oiric2006@gmail.com
May 2, 2018 12:18 AM
der Mond
Jul 17, 2012 11:11 PM
der Mond
Jul 11, 2012 08:41 PM
BankWalker
15
Oct 10, 2010 01:02 PM
gd3vbp
Apr 7, 2009 03:15 PM
