2nd Gen (GE8) Axle Shaft Came Out
Old Nov 7, 2015 | 07:31 PM
RedRocket_GE8's Avatar
I was putting my stock suspension back into my vehicle( I had put lowering springs on it before) and the driver side axle shaft came out of the transmission. I do not know exactly why this happened, thougb i suspect i put too much weight on it and was not paying attention as i was unbolting the sway bar.
Is there anyway to put it back in myself? If so what do i need? If i cant do it myself, can someone point me in the direction of someone or somewhere i need to go?
Thanks.
Old Nov 8, 2015 | 06:36 AM
Black3sr's Avatar
Do a search on here. Many have suffered this problem. A matter of patience and fiddling with it until it goes back in.
At worst have to cut the boot off get it running and take it in for new boot.
Old Nov 9, 2015 | 04:57 PM
I got it all back together and everything is running smooth except im hearing a noise whenever i go over a bump. Like metal shifting from side to side. At first i thought it was my strut tower, but that was tight and then i retightened my Sway bar witch was a little loose. thats fine now, but there is still a noise. not sure what it is.
Old Nov 9, 2015 | 05:05 PM
xxryu139xx's Avatar
check ur links
jfw432
Mar 31, 2019 02:38 PM
TexasWonder
Dec 13, 2017 01:07 PM
skytree
May 18, 2015 12:45 AM
jfw432
Sep 10, 2013 10:21 AM
808duece
May 13, 2009 04:10 AM
