2nd Gen (GE8) Axle Shaft Came Out
I was putting my stock suspension back into my vehicle( I had put lowering springs on it before) and the driver side axle shaft came out of the transmission. I do not know exactly why this happened, thougb i suspect i put too much weight on it and was not paying attention as i was unbolting the sway bar.
Is there anyway to put it back in myself? If so what do i need? If i cant do it myself, can someone point me in the direction of someone or somewhere i need to go?
Thanks.
Thanks.
Do a search on here. Many have suffered this problem. A matter of patience and fiddling with it until it goes back in.
At worst have to cut the boot off get it running and take it in for new boot.
I got it all back together and everything is running smooth except im hearing a noise whenever i go over a bump. Like metal shifting from side to side. At first i thought it was my strut tower, but that was tight and then i retightened my Sway bar witch was a little loose. thats fine now, but there is still a noise. not sure what it is.
jfw432
Sep 10, 2013 10:21 AM
808duece
May 13, 2009 04:10 AM
