Car battery related question (dead battery)
Old May 12, 2017 | 06:06 PM
ritholtz's Avatar
Hi,
I am getting battery indicator and some beeps for last 2 months. I am thinking about battery in the key fab. Now car won't start. It is completely dead. It doesn't work even with other key fab. Does it mean my car battery is dead completely. Is it possible to user jump starter and take it to Honda shop.
Thanks
Old May 12, 2017 | 06:17 PM
Fuelish's Avatar
More info ??? I'd start with key fob batteries and go from there,,,,dunno, I have a bare bones LX
Old May 12, 2017 | 06:21 PM
ritholtz's Avatar
Thanks Fuelish. For past couple of months as soon as I start the car, I keep hearing battery warning and symbol for few seconds. I thought it is for key fab battery charge. I was out of station for last 5 days. Today, I am not able to start Car. It doesn't even response for door open button on key fab. I tried with unused key fab. I can see light coming on key fab. But no response from car. I can use the key to open the door. Is there any key hole to put in the key and start ignition?
Thanks
Old May 12, 2017 | 06:30 PM
DrewE's Avatar
The battery light on the dashboard refers to the car's electrical system, not the key fob. Likely you would be able to jump start your car.
If you take only short trips and/or leave the car sitting unused for relatively long periods of time, the battery may well not be getting fully charged from driving. Using a battery tender while parked would help alleviate that problem. Taking an occasional longer trip, a half hour to an hour, would also help.
Old May 12, 2017 | 06:36 PM
ritholtz's Avatar
Thanks DrewE. I will try jump starting tomorrow morning and take it to Honda shop. I bought it on Jan 2015. I am assuming, it is still under warranty for battery replacement.
Thanks
Old May 12, 2017 | 09:18 PM
Splat's Avatar
Honda has a ten-year warranty on batteries, but it starts pro-rating at 24 months. My original battery died at 22 months, and thankfully was 100% covered under warranty. This is on a daily driver with LED interior bulbs and no extra power draws.
I bet you've got a bad battery as well, but a warranty replacement will cost you 10-20%.
Old May 13, 2017 | 09:28 PM
ritholtz's Avatar
Thanks for the information. I was not able to jump start with Accord. But towing guy was able to jump start with his truck. Honda replaced battery for free. They reported it as bad cell. I am still getting same low battery warning on console for key and warning sound at the beginning. I need to fix my key fab battery as well.
Thanks
Old May 14, 2017 | 08:08 AM
John Dahlmeier's Avatar
I looked through the manual the other day regarding that. The battery that comes with the car is under warranty for the 3 years/36k miles and a replacement would be covered by the longer one.
Old Dec 2, 2018 | 02:20 AM
╭∩╮(Ο_Ο)╭∩╮'s Avatar
Tray cut for 51r, assuming you have the small tray (mexican quality CVT.) leaving the little bit of the side intact on the inside small part helps hold the battery further away from the heat sink, but it wouldn't be the end of the world if you cut it flush with the end.
.The downside is if the battery leaks it can get on your frame, I'd like to have the proper 51r tray but I'm not going to order one, I'm too cheap.
My original 2015 battery died about two weeks ago.
Old Dec 2, 2018 | 12:02 PM
if you're worried about leaking, u can place the battery in a thick plastic liner (tape it to the side of the battery) and place it on the tray, no? not like that little tray's going to hold much fluid anyway especially in a moving car..?
cecevaqueraa
Nov 17, 2020 05:34 PM
KV43
Nov 1, 2016 01:46 AM
BenQuick
Sep 29, 2016 05:44 PM
hogwylde
Apr 3, 2015 07:30 PM
RAH
Mar 24, 2013 09:08 PM
