Tips on fixing Rusty license plate bolts on my trunk
Any tips on fixing and preventing this in the future
Found out the bolts on the license plate were rusty and bubbling from the previous owner so I wanna fix it ASAP. I was thinking about sanding the rust and bubbling and taping off just the area with bare metal that I sanded off, so I can primer, paint and clear. Since its behind the license plate and won’t be seen I don’t wanna blend the paint and clear in case I mesh up when spraying it.
When I fix and repaint won’t it rust in the future when screwing on the bolts won’t it take off the paint? Any ways to prevent it?
i would remove the chipped paint off as much as possible and coat it with rustolem. then use stainless screws to mount the plate on. might even use anti-seize.
What im worried about is when I screw on my screws will it strip off some of the new paint inside the bolt thread, is that what the anti seize will help with? im guessing the previous owner chipped the paint off with the screw. Might be a silly question but will get as much help as I can get. THX
You better not get paint in there, you won't be able to screw the bolt in easily. There is no clearance for paint in threads. A thread chaser or tap might be used to clean the threads to bare metal so they are usable again.
Apply anti-seize to the threads of the new stainless bolts before installing,
I've heard of plastic bolts as well for use with vehicle license plates, but haven't seen any in years
I think what I might do so paint doesn't enter the thread is screw in long screw not all the way to block it off when painting. Ill go buy some anti-seize like you and kenchan thank you for the tip!
+1 ^ But I'd use something like extend on the rust. SS bolts & call it good.
