DIY OEM Fog Light install on Base Fit
Old Mar 29, 2009 | 02:49 PM
  #61
lmsoares's Avatar
No my fit/jazz is 2004, so the fuse box is differente that was in the picture. The kit is oem, so i thought that I could do it by myself.
I will call some friends to help me to install that thing.
Old Mar 29, 2009 | 11:12 PM
  #62
lmsoares's Avatar
The 5pin connector in switch harness is bigger then in fuse box.... i getting crazy...kkk
Well i am looking with the kit supplier to see if he have the right connector..
Thanks
Old May 17, 2011 | 03:42 PM
  #63
nitros's Avatar
Dear friends..Am just chkng for the fog light installation here but i can't see the images.?? Thnks
Old May 17, 2011 | 04:30 PM
  #64
StormSilverGD3's Avatar
oops. My mistake. I shuffled some stuff around in my Photobucket account. I'll fix these.
Old Oct 16, 2012 | 12:24 PM
  #65
Images corrected once again. Moved everything off of Photobucket. Sorry for the inconvenience!
Old Apr 12, 2013 | 07:01 PM
  #66
rushlow's Avatar
Images are gone again
Old Apr 24, 2013 | 07:13 AM
  #67
rushlow's Avatar
Thank you StormSilverGD3 for the write-up and thank you to everyone for all your advice/tips!!! I installed my fog lights last night and everything is working great! I found OEM Honda foglight kit on ebay for like $65 or so.... pretty damn good deal
Old Dec 9, 2013 | 01:49 AM
  #68
madtodaimax's Avatar
Any chance of getting the images back? I just purchased a set from ebay.
Old Mar 15, 2014 | 03:26 PM
  #69
myfoxmystere's Avatar
Any tips on removing the 20 Pin harness from the fusebox? That is the one hangup I'm having in completing my installation. I've had success with everything else. Are there special tools to loosen the harness from the box?
Old Mar 16, 2014 | 01:20 AM
  #70
If you have the OEM kit, you can plug in the 20 pin connectors you have to one another to see how they lock together and then look how they come apart. Makes it much easier.
Old Mar 30, 2014 | 06:36 PM
  #71
GinoLicious's Avatar
I just did the install myself and have a few questions.
I found the plug with the blue tape but it is identical to the piece I want to plug into it. Is there only one brownish plug up there? My blue tape was just hanging on by a thread I didn't pull it at all. Also this 1 pin 2 prong brownish clip had a lot of gunk in it as well. Is this the clip I should be plugging in? If so, is my wiring garbage for the fog lights because the plugs look identical. No male and female to plug into. Also my wiring came with a built in fuse relay as well as it's own fuse to power it so that it didn't have to directly go i to the fuse box. Any suggestions would help. I have my lights installed but for some reason my wiring does not seem to add up. The brownish clip I'm referring to is so up there and you can barley pull it down. Not enough slack.
Old Apr 11, 2014 | 09:25 AM
  #72
fixed the image links again for anyone that may still use this!
Old Apr 12, 2014 | 11:53 AM
  #73
So I bought the replica fogs like another member on this board. Install is fine it's just wiring them up.
I would like to wire my fog lights into my head lights so when they go on so do the fogs without a switch. Don't really need or care for the switch. I know I have to splice the wire if the fog light harness and solder it to the headlights in one spot. Which wore would I solder it to?
Old Apr 14, 2014 | 04:59 PM
  #74
zipman72's Avatar
Cool Post.
Old Mar 21, 2015 | 06:10 AM
  #75
DWils's Avatar
Old thread question bump. Has anyone installed fog lights on a Sport replacement bumper for their Base model GD3?
Old Mar 21, 2015 | 08:09 AM
  #76
Sports bumper will have the cut outs for the fog lights. It's quite simple if you do not need to cut the bumper and it already has the slots. If it has the slots for the fog lights, the fogs should go directly in. If y are a base fit, you will have to wire your fogs. I created a diy in how to wire the fog lights. I would give that a quick read. It's real basic but it will tell you which wires to solder to your head light wires.
1. Since you have a sport bumper, your fog will screw directly in.
2. All you need to do after is wire the fog lights. Which I have created a DIY for.
Old Dec 24, 2015 | 04:55 AM
  #77
livelikegold's Avatar
im gonna handle this one soon.
Old Dec 2, 2021 | 10:39 PM
  #78
got a PM on this again and fixed some of the Image links. I think I'm missing a couple but I restored what I could find right now.
@PULOVR
JohnpaulX
Jan 12, 2019 01:59 PM
Oneoldphlaytis
Jun 27, 2015 04:33 AM
Dix GD3
Feb 12, 2013 08:02 PM
KCTitan
Nov 20, 2012 08:25 PM
sbualuba
Oct 17, 2009 09:40 PM
