Rotor screws?
Old Apr 18, 2011 | 01:10 AM
  #61
solbrothers's Avatar
you dont necessarily need an impact driver to get them off, but it helps.
Old Apr 18, 2011 | 07:11 AM
  #62
cr4zy3lgato's Avatar
mmmh... nice snap-on kit! the black cylinder is a "hand-impact" right?
Old Apr 18, 2011 | 10:55 AM
  #63
apexanimal's Avatar
thats the same took i used... works quite well...
for the life of me i couldn't remember what it was called...
Old Apr 18, 2011 | 03:47 PM
  #64
Krimson_Cardnal's Avatar
I think I rented one from AutoZone - free rental tools. They can work w/ a little heat.
Old Apr 18, 2011 | 07:06 PM
  #65
Carbuff2's Avatar
Originally Posted by whtsjdm
Lol. You goobers couldn't get the screws loose
< Sniff > Flattery? Nicest thing I've been called ALL DAY.
Old May 1, 2011 | 10:37 PM
  #66
kirko's Avatar
There are 2 ways ive taken them off easily other than an impact screwdriver. You can use a ball peen hammer and lay the ball side on the center of the screw, and strike the ball peen with another hammer. This will slightly flare up the edges of the screw and make it easier to come out, and break the rust on the tapered part of the screw.
I bought a snap-on air hammer with an impact screwdriver attachment. All you do is put the air hammer on the screw, and take a 19mm wrench, and twist while you pull the trigger on the air hammer.takes 2 seconds.
Old Nov 5, 2011 | 04:34 AM
  #67
Lyon[Nightroad]'s Avatar
Resurrection time. I ran into this problem, and the drill fixed it. Just drilled those little f***ers out. Replaced with $26 napa rotors, no screws, and everything is beautiful. These and the crank bolt have been the biggest PIA in all my time playing with the fit.
Old Nov 5, 2011 | 05:27 AM
  #68
whtsjdm's Avatar
Not sure why you'd waste that much time drilling them out. Impact driver or even some drills will back them out.
As far as the crank bolt goes, if you don't own an impact, have fun.
Old Nov 5, 2011 | 02:56 PM
  #69
Impact driver stripped them. Mine might as well have been welded in. I've got the 7-8 ft cheater pipe + jackstand combo down to a science now.
Old Nov 9, 2011 | 01:29 PM
  #70
D50boy's Avatar
Impact driver is $12 at O'Reileys. It's worth it for those suckers. ^^^ those crank bolts are always tough. I use two 1/2" breaker bars with cheater pipes and it's still a B.
I'd demand an alignment if they do anything to the suspension.
Old Jul 28, 2012 | 09:28 PM
  #71
coupdetat's Avatar
I'm gonna revive this stupid thread just to re-iterate that you do NOT need those horrible screws. I'm not sure why Honda puts these things in because they are incredibly obnoxious to remove. They turn a 30 minute brake disc job into a 4 hour swear-and-sweat-fest. I've broken multiple impact wrenches trying to get them out on a Honda Accord.
Take them out, or have a shop take them out. Throw them away and never look back.
Thurst63
Mar 14, 2014 11:48 PM
eddyksurfer
Apr 21, 2013 09:51 PM
sh00k
13
Mar 1, 2013 08:58 PM
awptickes
16
Sep 25, 2010 01:11 PM
vo1one
Jan 26, 2009 07:36 AM
