torqing lug nuts
Old 05-07-2013, 06:45 AM
FitRocket's Avatar
torqing lug nuts
what is the proper torque for the alloy wheels?
Old 05-07-2013, 09:09 AM
mkane's Avatar
^^^^^^^^^^^^^^60 ft-lbs
Old 05-07-2013, 12:08 PM
BMW ALPINA's Avatar
if I am not mistaken,
it is written in the owner's manual that the proper Torque is 80lb ft.
I my self torque them to 85 - 90lb ft just to be safe.
Old 05-07-2013, 02:06 PM
spreadhead's Avatar
Correct, factory service manual says 79.6 lb-ft. I torque mine to 100 lb-ft.
Old 05-07-2013, 05:02 PM
DaveFL's Avatar
Torque values probably are minimum, but more important is to check them after a few miles drive. Over torquing if not done slowly on opposites could do damage.
Old 05-07-2013, 05:17 PM
13fit's Avatar
Never go more then 5-10% over torque. Its too easy to torque to yield and render the studs useless, as the stud threading usually goes before the lug nut
I torqued my wheels to spec, then after driving for a few miles torque an extra 5 lb-ft
Old 05-07-2013, 06:50 PM
mkane's Avatar
Guess I'll tighten mine up a bit.
Old 05-07-2013, 06:55 PM
TPColgett's Avatar
I do mine to 85. Then after the next time I drive the car, I re torque. Always use a + style pattern. I change wheels A LOT LOL so I check this often.
Old 05-07-2013, 07:49 PM
+1 for TPColgett.... with torque wrenches being off about 5% (unless you have regularly calibrated wrench), it's better to over torque little bit to 85 than keeping it at 80 lb.ft ==> which could be actually between 76 to 84.
Old 05-07-2013, 07:56 PM
TPColgett's Avatar
HA, and mine is a $29 cheapie special. I double click all four lugs, drive to an event/home, and then double click again.
Old 05-07-2013, 11:38 PM
sr.sedan's Avatar
I do the factory spec , also don't want to over torque them, I heard that you could warpt the rotors by over torquing
Old 05-07-2013, 11:43 PM
solbrothers's Avatar
you should tighten them to the factory spec. Every time you tighten the nut too tight, you're stretching it. It's going to break at some point.
Old 05-08-2013, 12:39 AM
jmsplitfyre's Avatar
I torque mine to 80ft/lbs then re-torque after driving for 1000kms.
Old 05-08-2013, 05:46 PM
Carbuff2's Avatar
I use 80 Ft-lbs. Then I re-check within a few drives.
That said, with wheels, it's more important to have all the nuts tightened EQUALLY than worrying about a few percent higher or lower. So those "cheapie" torque wrenches are just fine.
Great Evil
09-15-2015 12:49 AM
Crawly
02-25-2008 10:36 AM
saralee
10-29-2007 03:13 PM
rossman
05-14-2007 09:27 AM
dave92029
09-23-2006 12:26 AM
Quick Reply: torqing lug nuts
