Ingalls Torque Damper
Old Apr 11, 2008 | 08:56 AM
  #41
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
Sorry, havent been able to get the pics up. Most important thing is that the o-rings go between the stiffy and the bracket, to reduce vibration.
Groc, if it's that far off, i would take everything apart and start over. mounted correctly, theres NO way the brackets would be 8 inches apart. I would try again, making sure the right spacers are in the right places, using the correct bolts, etc. I know the instructions are difficult, but they become clear if you read thru a bunch of times WHILE youre actually doing it. Any other questions, im always around
Old Apr 14, 2008 | 08:39 AM
  #42
GROC80's Avatar
Well it went on finally, but the preload adjustment was off. I was only able to set it at 15mm being the softest just to be able to install it. The damper length alone will not allow me to tighten the stiffness anymore. Why does it pop when I start the car? Is this normal? I read on the FAQ's it is due to preload being loose or a cold start. I had no trouble during driving, and the car felt fine. My friend told me the application may be different due to my fit being Automatic.
Old May 6, 2008 | 03:51 PM
  #43
NewEdgePerf's Avatar
Stiffy for Fit now in stock.
The Ingalls Engineering Stiffy Engine Torque Damper is back in stock at New Edge!
https://www.newedgeperformance.com/i...ROD&ProdID=589
Progress RSB Group buy with Free Shipping still on, get yours before the price increase announced by Progress takes effect!
Tony D
Your Ingalls and Progress Dealer.
Old May 8, 2008 | 04:03 PM
  #44
Im selling my torque damper Best offer shipped anywhere. I have to take it off cuz theres no room for it when i install the supercharger. Only has a couple thousand miles on it, perfectly clean, comes with all necessary hardware, bolts, etc...
PM me with best offer if interested.
The Voice
Dec 30, 2013 04:03 PM
Ryan2020
Jan 29, 2013 11:03 AM
Plink
Apr 14, 2009 10:57 AM
dickiez
Jan 23, 2009 09:20 AM
B1str0
Nov 22, 2008 01:06 AM
