who makes oil cooler for GD3 ?
Old Sep 27, 2008 | 11:32 AM
YeeFit's Avatar
Originally Posted by xtreme
I have never been able to figure out in my head where it connects too.. Thats the only reason i never got 1
can some one show me where the oil comes from and goes 2 please? will help me alot befor i go ahead and get 1.
Thanks
The sandwich plate (round circular piece) goes between your factory oil filter and the engine block. The oil then is routed through it and down the line to the oil cooler. The oil returns down the other line and back into the sandwich plate back into the engine. Pretty simple design and very effective. I've had mine installed ever since I've had my turbo and my oil temps have not been high at all.
Old Sep 27, 2008 | 03:08 PM
isitafox's Avatar
What are the benefits of doing this on a N/A Fit if any??
Old Sep 27, 2008 | 03:24 PM
xtreme's Avatar
I dont have a turbo but i want it cos i live in Thailand where its very hot and i like to drive pretty fast most of the time.. Cooler oil = better engine life and power right?
Old Sep 27, 2008 | 04:42 PM
FELIXY69's Avatar
add the oil filter adapter to the block where the oil filter is and then put the oil filter on top of the block,
and the adapter block there are 2 outlets ...one is out and one is in,
Old Sep 28, 2008 | 12:27 AM
JamesBizzle's Avatar
Originally Posted by JamesBizzle
so... I take in that you can install the Oil cooler sandwich onto the block, the temp/press sandwich onto the oil cooler sandwich, and then the filter on the temp/press sandwich? ... as long as you still have enough space for the Filter or run a shorter filter?
I'll ask again, can you fund both the cooler sandwhich and temp/press sand whichs togeather? If no, how can you run guages without tappng the oil pan?
Old Sep 28, 2008 | 01:44 AM
YeeFit's Avatar
The oil cooler sandwich on this universal kit has 4 ports on it. The 2 larger ports are used for the oil feed and return, and the other 2 are used for oil temp and oil pressure sensors.
No tapping needed, just the gauges with sensors and this oil cooler kit or another similar one. I am currently using the universal kit from AJ-Racing and I have an oil temp sensor/gauge hooked up to it, and will be adding an oil pressure. If you don't use both ports the other is plugged with a bolt.
Old Sep 28, 2008 | 11:59 AM
DOPE! That's exactly what I wanted to hear. Thanks!
JDMxGE8
124
Feb 15, 2015 10:14 AM
Odie
28
Apr 4, 2013 01:43 PM
Perrenoud Fit
Dec 27, 2011 07:22 AM
mozarwasagenius
Mar 31, 2009 12:54 PM
Paulo107
May 31, 2006 09:04 PM
