Weapon-r manifold = |
Old Jun 15, 2011 | 12:43 PM
  #81
DiamondStarMonsters's Avatar
Everything else is the same though?
Old Jun 15, 2011 | 12:46 PM
  #82
DOHCtor's Avatar
Yes but on my version i don't have acceleration enrichement mode...
Marko!!
Old Jun 15, 2011 | 12:50 PM
  #83
I am playing with 3.06 beta version and the x3.81.hex at the moment. Thanks again!
Old Aug 20, 2011 | 03:39 AM
  #84
DOHCtor's Avatar
Well i went into 3 different shops and nobody wants to even consider making custom runners for my manifold... unfortunately! I still think that the bigger runners and mismatched ports size (30mm on Head Vs 33 on the WR Manifold!) are what kills my low end torque... Grrrr!!!
Marko!
Old Aug 20, 2011 | 10:26 AM
  #85
Previc93's Avatar
i recieve my manifold in the mail about a week ago and the got it to a machine shop to weld in a bung fo the pcv/ boost gauge/ bov vacuum lines. should installed this weekend or next weekend if i get too busy.
Old Aug 20, 2011 | 10:29 AM
  #86
Texas Coyote's Avatar
I'm going to be waiting to see how you have done and how it works for you.. Hope you get get results.
Old Sep 7, 2011 | 11:43 PM
  #87
DOHCtor's Avatar
If i have known some details sooner, i would have kept the stocker with some polishing in the lower runner portion of the intake... Lost low end\mid-range grunt with the WR intake at the expense of a tiny little bit of top end power that i use, maybe, 5% of the time!
Personately, i will not put any bung for my PCV because the design of the manifold will result in a pool of oil in the plenum waiting to go down the intake or worst, hydrolock the engine on a serious turn... Catch Can MANDATORY!
Marko!!
Old Sep 10, 2011 | 03:34 PM
  #88
I picked up one of the 1st generation Weapon R manifolds that has been rewelded using inert gas along the seams after cracking and pressure tested at 25 psi.. I don't think I should lose much if any torque on the low end.. I was told that the car it was on tended to run lean with it and that with boost the problem could be more of a problem than it was on his N/A car.
Old Sep 10, 2011 | 04:17 PM
  #89
kylerwho's Avatar
spoon fed
when sugarfreak ran his N/A setup on the dyno he did lose some torque on the bottom end simply cause the runners have a bigger diameter than the oem.
yes i would recommend running a catch can heavily though
Old Dec 9, 2011 | 02:56 AM
  #90
SP1812's Avatar
I got the same problem with the weapon-R intake and pushing at 0.9 bar with my forged engine.
Old Dec 12, 2011 | 01:25 PM
  #91
Tofuman's Avatar
I want this Honda Racing HPD intake manifold to fit under the hood... Not likely without running a huge cowl hood.
Old Dec 12, 2011 | 03:43 PM
  #92
I had the .pdf somewhere with the part numbers. I want to know how much that dry-sump kit and the upper intake plenum costs...
kylerwho
17
Sep 9, 2011 01:09 AM
FELIXY69
30
Nov 6, 2009 03:39 PM
im the fit
Jun 16, 2009 07:36 PM
comptrekkie
Jan 7, 2009 10:26 AM
OneStopCustoms
Sep 27, 2008 01:21 AM
