Strup Header Review
Old Jan 7, 2016 | 12:10 AM
h8rsama's Avatar
Some pictures I took that day
Originally Posted by Jimmyjoejak
Yup, it has the 3 nuts for the heat shield but the flange that accepts the spring bolts also has another hole for the bracket that mounts to the transmission. The OP said this too.
"Only weak point thus far is it doesn't have an option to mount to the stock vibration bracket at the transmission, although it doesn't seem to affect it, I'm sure other headers remove that as well."
I'm just wondering if omitting this will cause any long term problems since now the header is only held by the header bolts and the connection to the cat.
Oh yeah. But I forgot to mention one big thingy: I'm overseas and is slightly different so no bracket from start
Not sure if helps
Old one is different. No O2 sensor here. Down in the cat
Attached Thumbnails Strup Header Review-80-20151223_133103_53dd6841ff7291e67dff9b4b6e7c7bece8bd4756.jpg   Strup Header Review-80-20151223_135812_ddde35a1b2df8b7daac3c76425bb0ec5525f310c.jpg   Strup Header Review-80-fb_img_1450889267459_0fecbc8e7483f1343fea0d1d9b653cfb9bf6e42c.jpg
Old Jan 7, 2016 | 01:11 AM
Jimmyjoejak's Avatar
Hey h8rsama,
Can I ask where you're located? From your pics it looks like the stock headers have the mounting hole but your car doesn't have the bracket.
Old Jan 8, 2016 | 11:52 AM
h8rsama's Avatar
Hey h8rsama,
Im in Colombia, and so far i know My car comes from Brazil/japan and it looks like EDM JDM
Old Jan 8, 2016 | 01:20 PM
Yeah. Looks like the JDM cars might not use the bracket. I wonder why the USDM have it?
Old Jan 9, 2016 | 08:05 PM
Hey guys,
I know that you can't use the stock heatshield with the aftermarket headers. Any of you guys have issues with the engine bay getting too hot without the heatshield? Esp with the coil packs just above the headers?
Old Jan 11, 2016 | 10:06 PM
h8rsama's Avatar
Hey guys,
Mmm hard to tell but I dont think that would be an issue. Any brand you find wont have it
Old Jan 25, 2016 | 06:32 PM
Just wanted to give an update. I did the install this weekend and it wasn't very difficult once I got a flex head 1/2" long handle driver. Without it, I was not able to get the header mounting bolts and nuts off. Once I had the old header off, install of the new one was pretty easy. I was not able to use the OEM vibration mount because the Strup headers doesn't have the extra mounting hole in the lower flange. I did re-use the OEM heat shield by getting a welder to weld some brackets and bolts.
Performance wise, I feel the header smooths out some dips in the lower RPMs and provides a smoother power delivery.
Old Jan 25, 2016 | 06:49 PM
Myxalplyx's Avatar
Originally Posted by devmail
These are selling super cheap on eBay STRUP 4-1 EXHAUST HEADER STAINLESS STEEL 2007-2008 HONDA FIT H21103 FOR RACING
$69 + free shipping, these were originally $300!
Got mine yesterday
Man....this thing is just a thing of beauty. Really!
Attached Thumbnails Strup Header Review-43af1a03-b651-4d80-9d39-f0a752b1f527_zpszhpdw6ky.jpg
Old Jan 25, 2016 | 07:04 PM
h8rsama's Avatar
Plz post a picture of your brackets
Old Jan 27, 2016 | 05:41 PM
I basically just got some metal "L" shaped brackets and 6mm bolts from HomeDepot and just stuck them on the header flange with duct tape using the heat shield as a template. I then gave the mocked product to the welder for him to tack on. You can bend the "L" shaped brackets to align to the holes with the heat shield.
Old Jan 28, 2016 | 02:24 AM
h8rsama's Avatar
Cmon Jimmy......dont be this selfish.....just post your finished product phote
Old Apr 21, 2017 | 11:46 AM
  #32
mangosmoody's Avatar
i have this header its great for sure
Blue-Civic-Hybrid
Nov 27, 2010 08:26 PM
Staff@WR
103
Sep 17, 2008 04:54 AM
drzenitram
Jun 14, 2008 03:23 AM
prossett
13
Nov 29, 2007 09:15 AM
