AT Transmission Cooler
Old Jan 16, 2007 | 12:34 PM
  #81
leonine's Avatar
Originally Posted by leonine
still waiting for my damn sending unit. tried to wire up the dimmer on the gauge but no luck. anyone know what i can connect it to. i need a 12v only when the headlights are on and no power at any other time. Either that or i will cover the gauge with tint. it's a blue led and it is so f'n bright at night it's burning my retina.
Think i found a good power source for the dimmer. The RED/YEL wire going to the fog light relay is only live when the headlights are on (at least that is what i read in the independent fog light thread). Tomorrow when i install the new sender and rewire my fog lights i will hook it up. Hopefully that will work as well as make my fogs independent.
Old Jan 16, 2007 | 08:20 PM
  #82
spider2k's Avatar
also you can look for a red/black as its normally parking lights in a honda.
Old Jan 17, 2007 | 05:44 PM
  #83
leonine's Avatar
finito!
got the new sending unit installed today. Still reading a it low though. I might disconnect the tranny cooler until it warms up in the spring.
Anywho, here's a couple of pics of the gauge. Got it to dimm by hooking it up to the red/yel wire in the headlight switch.
Old Jan 18, 2007 | 12:15 AM
  #84
03DSM-RSX's Avatar
Frequent FitFreak Poster
so how did you ground it this time?
Old Jan 18, 2007 | 12:39 AM
  #85
leonine's Avatar
the new sending unit has 2 wires. 1 for temp and 1 for ground. I ran the ground to the gauge ground and tapped that connection to the engine block.
Old Jan 18, 2007 | 08:34 AM
  #86
leonine's Avatar
Originally Posted by claymore
That is a GOOD looking gauge, do they also make the normal set of oil pressure, Water temp, and volt meter?? Are you sure it's reading in Fahrenheit and not Centigrade??
They have all the gauges you mentioned above plus more.
go to Cyberdyne Guages Home and check them out.
That is a GOOD point. i never thought about Fahrenheit vs. Centigrade. I guess i will be calling them shortly to find out.
EDIT: just checked their website and it states trans temp gauge reads from 70 - 260 Fahrenheit. I need to find out what the normal operating temp range is for the Fit dammit. The f'in helms manual doesn't say.
Old Jan 18, 2007 | 08:55 AM
  #87
gettinafit's Avatar
Nice Install! Good thing you found a wire that give B+ sorry I for got to check out that fuse for you! Now i'm on Fitfreak, And saw your post and was like... oops! Anywayz, did you figure out a dimmer B+ circuit?
Old Jan 18, 2007 | 08:58 AM
  #88
leonine's Avatar
there was only one wire for dimm coming out of the gauge. i connected it to the red/yel wire coming to the headlight switch which only gets power when the headlights are on. works great. now i can see at night without the blue led burning my retina.
Old Jan 18, 2007 | 10:28 PM
  #89
gettinafit's Avatar
So the dimming is working! Even Better~!
Old Jan 18, 2007 | 10:37 PM
  #90
leonine's Avatar
yeah it works great. and now i also have indepedent fogs!
Old Oct 25, 2020 | 05:30 PM
  #91
big Fit's Avatar
Originally Posted by 03DSM-RSX
there is no real purpose of having a ATF cooler on a basic AT car. the last thing you would want is the ATF to go below its warmed up threshold. (which wont likely happen anyways)
if you're concerned about heat issues, you're better off switching to Amsoil synthetic ATF. (only kind that can replace Honda ATF)
Synthetic oil is alway great under heat conditions. I have one experience which my 2007 sport fitHonda automatic transmision got hot. I was driving elevation . Driving up to mt walker in Olympic national forest. I pulled off the road because there was nothing i could do about it. Seems a cooler would be nice.I had done that same drive in a base fit with manual tranny and did not have the heat problem.
Lyon[Nightroad]
Apr 4, 2017 12:20 AM
Odie
Jul 22, 2014 07:24 PM
Odie
Jul 21, 2014 10:02 AM
champagnefit08
Oct 28, 2009 12:47 PM
bestfit
Feb 17, 2007 07:11 PM
