TRS LED Headlight Assembly
Old Oct 22, 2020 | 04:49 PM
  #81
Macswfc's Avatar
Originally Posted by Goobers
Assuming the Fit is aligned with the road, the step in the cutoff seems a bit far too the left. That could've been what caused oncoming traffic to flash you.
I hear you. This is a very narrow road I am on, out in the middle of nowhere. On a regular road my cutoff comes down at about 1/4 of the road on my side before the middle line. I might play with it a bit more but like I said no flashing all last night. We will see how it goes.
One thing I’m noticing with the headlights is when I move the left light cutoff to the right it also travels down....so I have to adjust the height afterwards, doesn’t do this on the passenger side one, I’m weary about cranking it anymore as I’ve read that the adjustment components can fail if manipulated too much.
Old Oct 22, 2020 | 05:43 PM
  #82
Goobers's Avatar
It should do this on the passenger side, but more likely in the opposite direction.
The adjustment components are basically a loosely mounted bolt and nut. And just most nut & bolt pairs, if you over crank it when its tight, it'll strip the threads. This is made even easier because the nut is likely plastic too. Of course, if you over crank it in the opposite direction, it could simply pop out. That isn't "as bad," but not very easy to fix unless you're comfortable taking headlights apart.
When I lived in San Diego, I had drove a Mitsubishi Mirage (aka Lancer) and swapped out the H4 headlight for a H1+H3 headlight. And for one of the bulbs, one adjuster came completely off, so I had to use a piece of coat hanger wire to hold it in place.
The two adjusters are basically two of three mounting locations that hold the inner headlight to the outer shell. So, it should be easy to imagine that a particular adjuster moves the headlight around an imaginary line that goes through the other two mount points. So, like a triangle, no matter what orientation you put it, at least one will cause it to pivot in both horizontal and vertical directions.
That said, while I'm purely guessing, it should be okay so long as the angle isn't extreme. Though I suppose it could be a tight fit with little room for it to move to begin with. If you feel it getting a little hard to turn, you might be at the limit.
Old Jul 11, 2021 | 12:38 AM
  #83
Wht_GK5_Tx's Avatar
Question need some clarification on harness plugging
Originally Posted by Helios
I took one of the lamps out to the car and plugged up the adapter harness.
The H4 connector on vehicle harness side plugs in to an adaptor that splits off into two connectors on the headlamp harness. Connectors are nice and have water tight seals.
The DRL plug on car harness side isn’t used. You use the harness they sent to connect and run between both headlights and to the fuse box. It plugs into 30. Remove the 10A fuse that is there and replace with the plug with the kit. Fuse box lid will need modified to fully close.
The last connector is for the turn signals. It just plugs in.
You can only tell so much looking at a headlight lit up at 6pm pointing at your good, but in my opinion they look freakin sick and I can’t wait to install.
edit: after actual install I corrected my wiring walkthrough.
Can you please send a picture or something that clarifies where the DRL harness plugs in to the fuse box and in to the headlights, i cant seem to find where position 30 is in the fuse box; well i did find it but i dont trust the source because their location 30 isn't headlight related. Also, my headlight set from TRS didnt include any instructions.
Thanks a million for this info, i will upload pics after i finish this install. Again many thanks.
Old Nov 13, 2021 | 11:41 AM
  #84
Done Deal DR's Avatar
Did you end up getting this figured out? I can take a pic of what the fuse panel should look like if you still need it.
Old Nov 28, 2021 | 08:02 PM
  #85
millerlite's Avatar
what’s the purpose of the harness and where does it plug the exterior or interior fuse panel?
Old Nov 29, 2021 | 07:19 AM
  #86
Wht_GK5_Tx's Avatar
TRS headlights for GK5
A picture of where this plugs into a how it comes off the fuse box would be awesome.
Also I heard the DRL stays on about 5 mins after you turn off the car, would this merit a yellow top battery upgrade?
or maybe some coilovers? I dunno. Lol.
Old Nov 30, 2021 | 03:22 AM
  #87
millerlite's Avatar
do your low beams stay on along with the DRL, because mines do and I my understanding was only the LED strips should stay on.
Old Dec 2, 2021 | 10:13 AM
  #88
millerlite's Avatar
So I just got off with retrofitsource as morimoto replied to me stating that these headlights aren’t serviceable so we can’t replace the bulbs, are these still worth it considering that factor?
Old Dec 2, 2021 | 11:10 PM
  #89
Wht_GK5_Tx's Avatar
Cool The price you pay for being cool.
I had the same thought when i bought mine but, got them anyway. its been 4 months now and no issues so far. they do have warranty and from what ive heard these bulbs are long lasting. If they go bad in 2 -3 years just chalk it up to the price u pay for being cool.
Old Dec 3, 2021 | 01:45 AM
  #90
millerlite's Avatar
I’ll email them back and see if they can just swap them for a projector kit as I didn’t really want to do that since these were plug and play. I also went back to the listing and they compared them to their fog lights as they are also built in the same and seem to hold up after 5+ years but I wished they had actually be more specific about it. The warranty it’s at 5 years but does it cover the LEDs as they are wear and tear if we can say regardless of it they are pretty good compare to those $300 cheap projector headlights.
Old Dec 10, 2021 | 08:29 AM
  #91
Wht_GK5_Tx's Avatar
So right now i haven’t hooked up the DRL plug bit but, yes you are right only the strips should stay on. Maybe you have your head lights set to auto?
Old Dec 10, 2021 | 08:33 AM
  #92
millerlite's Avatar
i ended up removing the fuse as they would keep on but regardless of it I ended up returning the headlights back
Old Dec 10, 2021 | 10:53 AM
  #93
Wht_GK5_Tx's Avatar
Sorry to hear that man.
Well, now you can look at those taillights with the waterfall effect.
Another fun project that will bring frustration, maybe a cut on the finger and then pride. . . Lots of pride.
Old Dec 10, 2021 | 12:20 PM
  #94
millerlite's Avatar
actually I didn’t like the reflector taillights on the hatch, I ended up wrapping them in black vinyl.
But wil definitely be doing a retrofit next year.
calafricano
32
Nov 29, 2019 11:57 AM
BMW ALPINA
23
Dec 8, 2018 01:24 AM
Nuno Quintelas
Feb 11, 2017 08:56 PM
pacothebandit
17
Oct 8, 2016 07:22 AM
Fit4Spl
May 22, 2011 11:54 PM
