Spring install help
Old Mar 15, 2009 | 12:34 PM
gd3vbp's Avatar
Spring install help
Anyone else have issues getting the nut on top of the front strut loose? I'm having problems getting the nut loose on the drivers side, so much so that I think the alan key spot is going to strip before I get it loose. Any ideas?
Old Mar 15, 2009 | 02:42 PM
grtpumpkin's Avatar
Spray a little WD40 or Liquid Wrench on it and let it sit for a while. If you have access to air tools use an impact wrench on it (thats what I did) It may also help if you hold onto the Allen key with a pair of Channel Locks to give you more leverage. Lastly put a spring compressor on the spring to take the tension off that top mount. In the DIYs on here they say you don't need to but I respectfully disagree, especially if you are having a hard time with that top nut. If you are talking about the under hood retainer that has to come off in order to release the top of the strut from the car, stop, take deep breath and make sure you are turning it in the right (correct) direction. It sounds stupid, but it just might be your problem. Good Luck!
Old Mar 15, 2009 | 03:01 PM
gd3vbp's Avatar
Thanks, thats what I was worried about, I'll have to find someone with an impact, and I'll either have to find or buy a new deep 19mm to get it off. Its been soaking in pb blaster for 2 days and its not budging.
Old Mar 16, 2009 | 10:45 PM
grtpumpkin's Avatar
My drivers side one had me wondering if I shoulda had my Wheaties that morning. Then I slapped myself in the forehead and said "Do-oh" Went out to the garage and fired up the compressor. I didn't have a 19mm impact socket but the 3/4 was close enough to git er done. The other reason I advocate using the spring compressor is it gives you something to clamp in your bench vise. Trying to hold onto the strut with one hand while holding the Allen key and turning the socket wrench will leave you talking to yourself in a big hurry LOL Hope you get it loose, all the frustration is worth it!
Old Apr 4, 2009 | 02:39 PM
gd3vbp's Avatar
Got it done in about an hour today, borrowed an impact from a friend and that bolt came right off. I miss having air tools at my disposal...
Shitty quick pics, I just grabbed the point and shoot my fiance left out.
Old Apr 4, 2009 | 08:58 PM
grtpumpkin's Avatar
Air tools FTW. Drop looks good, nice and even. Which springs are they?
Old Apr 5, 2009 | 12:24 AM
Fat Ping Cat's Avatar
definitely a nice install. what kind of springs???
props!
Old Apr 5, 2009 | 12:40 AM
enjoito's Avatar
looks good man. i had mean problems with axle popping out.
Old Apr 5, 2009 | 01:09 AM
gd3vbp's Avatar
Thanks, they're Skunk2's. I was skeptical at first, I really wanted Teins, but I'm happy with the choice.
Old Apr 7, 2009 | 02:27 PM
yes, most definitely looks good.
Old Apr 7, 2009 | 03:15 PM
gd3vbp's Avatar
Thanks man, its odd getting used to dailying a lowered car again. It feels almost as stiff as my old accord.
oiric2006@gmail.com
May 2, 2018 12:18 AM
Bruce Huff
Oct 7, 2015 02:06 PM
apexanimal
Mar 23, 2014 02:45 PM
ej20i
Oct 21, 2010 04:40 AM
kancerr
Mid-Atlantic Community
Sep 18, 2008 12:04 AM
