Anyone have a price on OEM shocks and struts?
Old May 14, 2009 | 02:26 PM
runbikerun's Avatar
Just curious what it will cost to replace my shocks/struts down the road. 09 sport if this helps. I think I will have near 60000 on my fit by the end of next year.
Old May 14, 2009 | 07:12 PM
GD3_Wagoon's Avatar
$207.42 each according to bernardiparts.com
Old May 14, 2009 | 08:41 PM
redrumm's Avatar
by the end of the year most people will have lowered fits and you can probably buy them used for cheaper than the dealer
Old May 15, 2009 | 05:24 PM
^^ very true.
Old May 19, 2009 | 10:57 AM
wdb's Avatar
wdb
That's for the entire shock/spring assembly. The shock alone is $106.14 each for the front and $80.56 each for the rear.
Old May 19, 2009 | 11:45 AM
GD3_Wagoon's Avatar
doh.. i've overlooked that, thanks for clearing it up
Old May 19, 2009 | 10:08 PM
runbikerun's Avatar
Thanks for the info. I figure if my new springs blow my oem shocks at least the replacements won't be so expensive.
Old May 20, 2009 | 12:00 PM
wdb's Avatar
wdb
Think seriously about aftermarket shocks if you blow the stockers. T1R's are only a little bit more expensive, they're adjustable, and they're designed to work with lowering springs.
Old May 20, 2009 | 12:55 PM
runbikerun's Avatar
Thanks. Would you happen to know if the ride height can be adjusted with the T1R's?
Old May 20, 2009 | 09:31 PM
wdb's Avatar
wdb
No. They're just dampers, shock absorbers. They will change the way shocks are absorbed, end of line.
If you want to adjust ride height you have two choices.
1. Springs. A lot of them (truth be told, all of them) lower the car. Some of them lower the car to improve looks, some of them lower the car to improve handling, and some of them could care less about either.
2. Coilovers. These allow you to set ride height via moving the lower mounting point of the spring. See #1 for more information about what else they do.
Old Aug 18, 2009 | 09:17 PM
Selden's Avatar
Is there a T1R shock for the GE, or only for the GD Fit? Where does one find them?
shawnshank
Mar 30, 2018 05:34 PM
hello_you1
Jul 5, 2015 01:19 PM
Bean_Garage
Jul 28, 2014 06:04 PM
linnboi
Dec 2, 2012 12:19 AM
kkim
13
Dec 10, 2007 03:28 PM
