Sponsored by:
Sponsored by: CARiD
Driveline forum?
Old Jun 11, 2010 | 10:57 AM
  #41
JCrimson's Avatar
Any word on this? I would like to order the parts to day but I see where you said you ordered a wrong part. can I please have an updated list of the correct parts from summit racing. and did you order a omni CMC? which one?
please let me know asap. thanks!
Old Jun 11, 2010 | 11:01 AM
  #42
apexanimal's Avatar
i'm about to walk out to do this... if the parts aren't correct it should only take me about an hour or so... if they are, it'll take a little bit longer...
Old Jun 11, 2010 | 11:04 AM
  #43
JCrimson's Avatar
Thank you much! Ill be stalking this thread
Old Jun 11, 2010 | 01:13 PM
  #44
apexanimal's Avatar
no good news in this post:
i got tingles when i found the russell "universal" clutch adapter p/n640281... so on a desperation move, i ordered it from jegs...
the length is correct, but once again, by about 1/32", it's too narrow and wouldn't hold a seal correctly...
so to recap:
the ss line listed is correct
the 90* coupler is correct
the two adapters that are necessary to attach the -3an fittings to the cmc/csc are unknown at this time
i'm beginning to get frustrated now...
Old Jun 11, 2010 | 01:30 PM
  #45
apexanimal's Avatar
are we pretty certain that the adapter would be a metric one?
i'm only assuming so since it's a foreign product...
if so:
i found a few -3an to 12x1.0mm adapters... i'm trying to figure out what kind of flare we need... i'm believe we'd need a bubble flare...
i need some help now... i don't want to order another adapter without some more research this time...
Old Jun 11, 2010 | 02:38 PM
  #46
lcq4blackstar's Avatar
if so:
So is your car down then? are you able to remove the master cylinder? If you've got it out of the car take it to transmission shop. The adapter is going to be metric for sure. Can you take a picture of the original brass piece that the factory line connected to? I'm going to be working these next couple of days or I would head to some shops myself. Do you think you will at least be able to return those other adapters? I think if you go to a shop that does trans work this won't be an issue as they have seen everything.
Old Jun 11, 2010 | 02:55 PM
  #47
apexanimal's Avatar
the car isn't down... my wife needs to drive it pretty much everyday, otherwise i would've done what you said and just taken it in somewhere...
i should be able to return the adapters... less shipping and whatnot... but i'm going to hold off until this project is done just to be certain...
i've been digging around honda-tech, and i think the 12x1 to 3an will work... it seems to be a popular size on honda mc's...
here's what i'm looking at right now (and for my reference later):
AN PLUMBING.COM Earls performance products Hose ends Hose,Adapter fittings
p/n - 305-03M121
Pegasus - Male 12 x 1.0mm Metric Convex Seat to 3AN Male, Steel
Pegasus - Male 12 x 1.0mm Metric Concave Seat to 3AN Male, Aluminum
Old Jun 11, 2010 | 03:06 PM
  #48
apexanimal's Avatar
so essentially the choice is down to a convex, concave, or bubble flare for the adapter...
and if i remember correctly, it's either a convex or bubble...
Old Jun 11, 2010 | 03:27 PM
  #49
Post up if you've removed the piece in the second pic and post up a pic of what the end looks like so I can find out what the end is called, thanks.
Old Jun 11, 2010 | 03:36 PM
  #50
Inverted flair is what you want (99% sure)... here's a reference article on this done on Honda. This Honda used 10mm adapters though...
Honda Clutch Line Installation - Steel Braided Bling - Honda Tuning Magazine
Very curious if you had that brass piece in the second picture installed or not when fitting the new line. We could very well need 12mm as you've said but just find a 12mm version of those Russell adapters I had listed. As far as the 12X1mm side, I don't think there is anything special about that side of the adapter, you would know better as you've had it apart.
If you took some pictures when you had it apart it would be a huge help on this! Thanks!
Old Jun 11, 2010 | 03:47 PM
  #51
apexanimal's Avatar
yes
yes
i have removed the stock adapter fitting... i don't think we're going to find a honda clutch adapter to -3an... i'm nearly certain it's not made...
i did some more digging on honda-tech and found a guy who knows what he's talking about... he said if it's not a 10mmx1.0, it's 12mmx1.0... and you're right... we do need the inverted flare to seal correctly - my bad...
can anyone find one like this (below) but in steel?
Old Jun 11, 2010 | 04:02 PM
  #52
apexanimal's Avatar
pics:
stock metric thread onto stock cmc adapter
stock metric 12mm vs 10mm as first thought
stock cmc adapter (right) vs russell adapter (left) - notice the russell is ever so slightly thinner
Old Jun 11, 2010 | 04:07 PM
  #53
apexanimal's Avatar
i'm also beginning to believe that the cmc adapter needed is a 12mmx1.0 while the csc adapter needed is a 10mmx1.0...
glad i didn't return the adapters
Old Jun 11, 2010 | 04:11 PM
  #54
I wouldn't use an aluminum one, check this one.
AN PLUMBING.COM Earls performance products, Hose ends Hose,Adapters, fittings
First part (#592032) listed looks good, can you confirm that's what it looked like when you had it apart? "Works with Inverted or bubble flare. Steel Brake Adapter 2 per pkg" I'm pretty sure this is what we need...
Old Jun 11, 2010 | 06:49 PM
  #55
apexanimal's Avatar
that link you gave just sends me to the main page... what part number did you want me to see?
592032 looks ok, but it's still the 10mmx1.0... not the 12mm that's needed...
305-03M121 is close but it's bubble only... doesn't say it'll work with inverted flares...
Old Jun 11, 2010 | 11:09 PM
  #56
Haha I wonder where my brain is sometimes...(probably because I was doing 50 other things at the same time) yeah I got them mixed up. You are correct 305-03M121 is the one we are looking for. That site won't let me link past the main page I guess? Anyway I sent them an e-mail to make sure its compatible(as far as working with inverted flare). I'll keep you posted when I hear back apexanimal.
Old Jun 12, 2010 | 07:56 AM
  #57
apexanimal's Avatar
i found a vendor on honda-tech who says they stock the correct 12mm to 3an adapter that we would need... 8 + shipping...
i'm going to try to confirm that we only need one of those then order it...
keep us up to date about the one you're going after and i'll do the same...
going to a ptgt mod party now...
Old Jun 12, 2010 | 12:28 PM
  #58
apexanimal's Avatar
just ordered the adapter from the vendor...
going to ship priority probably monday... get it later in the week...
he said he's never seen a honda that had a 12mm adapter for the slave... so i only ordered one for the master... and I WILL KILL SOMEONE if it doesn't work this time... punch right in the throat...
anyway... more info as it comes...
Old Jun 12, 2010 | 03:36 PM
  #59
Apexanimal, here is what they had to say about P/N#305-03M121
"pull the inverted brass nipple insert out of the cylinder and it will be bubble flare and work fine with this part"
EARLS Store #1
http://www.ANplumbing.com
310 542 6435
Old Jun 12, 2010 | 04:22 PM
  #60
apexanimal's Avatar
EARLS Store #1
310 542 6435
awesome... you want to try that one and i'll try the one i've ordered and see which is better?
finally starting to get somewhere...
