Check engine light
Old Jul 15, 2023 | 11:46 AM
Mcpherson1's Avatar
Check engine light
Hey guys please help..i jump-started a friend last week...he mistakenly swapped positive with negative terminal.. there was a bit of a spark after that my check engine light came on...i unplugged my battery and plugged it again the light came off...after a while it came on again..every time i remove the terminals it comes off but after a while it comes back on again. What could be the problem???
Old Jul 15, 2023 | 07:08 PM
mkchiu's Avatar
What does a OBD scan tool say the Check Engine code was?
Old Jul 16, 2023 | 03:48 AM
Salikoia's Avatar
Hey,The check engine light coming on after a jump-start where terminals were swapped suggests an electrical issue. Possible causes include a faulty O2 sensor, blown fuse, damaged wiring/connectors, or issues with the battery/alternator. To resolve it.
  1. Get the error codes scanned to identify the specific issue.
  2. Inspect wiring/connectors for damage or loose connections.
  3. Check and replace blown fuses related to the engine management system.
  4. Consider seeking professional help if unable to diagnose or fix the problem. Don't ignore the check engine light.
Old Jul 16, 2023 | 03:50 AM
Salikoia's Avatar
Hello,
An OBD scan tool tells you the Check Engine code(s) stored in your vehicle's computer system. These codes indicate specific issues with the vehicle, but further diagnosis is usually needed to identify the exact problem.
Old Jul 24, 2023 | 10:51 AM
Chitown Fit's Avatar
Jump Start Booster.
Buy a jump start booster. Then you won't have to jump start someone using jumper cables.
Old Jul 24, 2023 | 10:57 AM
Noco GB40 Jump Starter.
132 dollars at Autozone.
yogs
Jun 1, 2025 02:46 PM
BlackPearlFIT
Apr 9, 2012 11:24 AM
paulfit
May 14, 2010 02:02 PM
hazzard
Nov 14, 2008 02:55 AM
FELIXY69
Oct 13, 2007 11:30 AM
