Brake pedal "clicking" sound and ABS system
Old Jun 10, 2008 | 01:59 PM
TiMo's Avatar
Hello guys,
I really don't know if you guys have the same problem as me. When I apply my foot on the brake pedal everytime, and I can hear one clicking sound. It's very annoying because it's very noticeable when I step on the pedal. I brought my car back to the dealership, and the "service consultant" explained to me that it's because something related to the brake light switch and won't be able to fix it for me.
Also, have you guys notice that the ABS on 2008 model is very sensitive? When I'm trying to stop the car from above 40km/h, and it goes over on an unbalanced area. I can hear the ABS is started to lock up and the system is vibrating.
Old Jun 10, 2008 | 02:58 PM
acutally since running the EnduraTech's with soft spring rates, i have
yet to get any ABS noise on dry surface. on occasion when i
make fast stops in the rain i get it, but even that is rare.
the abs noise has direct relationship to the suspension setting and alignment.
Old Jun 10, 2008 | 03:04 PM
TiMo's Avatar
The consultant told me that the ABS system for Honda/Acura 07/08 models had changed, and that's why it's more sensitive. I'm okay with the ABS thing but I'm getting so annoying of the little "clicking" sound everytime I press the pedal.
Old Jun 10, 2008 | 03:31 PM
DaBOM's Avatar
Originally Posted by TiMo
Hello guys,
Happens to me as well. I knew the clicking is the brake switch, I just learned the deal with it. The ABS thing, though, is very annoying.
Old Jun 10, 2008 | 03:33 PM
Flyin172s's Avatar
I noticed when I brake at very slow speeds, like while turning into a parking spot, the ABS will activate. It's not every time, and it doesn't bug me too much, as long as when I have to slam on the brakes the ABS works then too, I'm cool with it.
Old Jun 10, 2008 | 03:37 PM
did the consultant also tell you that you'd get less noise if you used
better tires? he probably forgot to do that.
Old Jun 10, 2008 | 03:39 PM
TiMo's Avatar
I think this is how the ABS works on the newest model. I don't mind as long as it works at a right time.
Old Jun 10, 2008 | 03:40 PM
TiMo's Avatar
No, he didn't tell me that. Did you mean that if I change a better tires, I will get less noise from the ABS when the system is locked up?
Old Jun 10, 2008 | 03:52 PM
while using better grippier tires the system will not lock up as easily and let
the tires do more of the work than asking for the ABS's help.
so yes, better grippier tires will raise the threshold before ABS needs to
kick in.
not sure about that clicking noise though... mine does not make any
audible clicking noise. on the AT's you're hearing the solenoid inside
the shifter..
Old Jun 11, 2008 | 12:54 PM
TiMo's Avatar
I have to learn to deal with it. I went to my own auto bodyshop and the "clicking" sound it's about the brake switch for the braking light. So, there's no way to fix it. I probably will just turn on the stereo system.
diesehrl
Aug 2, 2016 01:33 PM
R2D2
23
Nov 29, 2008 01:24 PM
cycoxtr
Jul 7, 2007 09:24 PM
Jimmy101
Sep 14, 2006 01:05 PM
p1driftfiend
May 19, 2006 07:17 PM
