which wire to use on lower driver left kick panel for hardwire
Old Jul 7, 2008 | 04:24 PM
Charlie97L's Avatar
i'm hardwiring my garmin nuvi, and i need to know which wire to splice to on the driver left kick panel.
any suggestions would be awesome!
Old Jul 7, 2008 | 06:18 PM
mdm427's Avatar
Here's my fuse panel, and you can see where I tapped into fuse location 5 to power my lumbar support. Location 5 is only hot when the ignition is on. If you want a line that's always hot, you can use 18-20. You can use any location with the ADD-A-LINE because it just piggybacks the fuse location. Since there were open locations, I just used one of them.
Old Jul 7, 2008 | 10:17 PM
Charlie97L's Avatar
thanks! so are 18-20 always hot, even when the car is off? i want the radio to turn off when the car goes off.
thanks.
Old Jul 7, 2008 | 11:00 PM
mdm427's Avatar
Yup, 18, 19, and 20 are always hot, even when the ignition is in the off position. If you want a source that turns on and off with the ignition, then use number 5 like I did in the picture.
Old Jul 8, 2008 | 07:55 AM
Charlie97L's Avatar
thanks so much, this was a VERY informative post. you rock!
Old Jul 8, 2008 | 03:07 PM
mdm427's Avatar
No prob! Glad to help when I can.
SilverEX15
Feb 12, 2019 07:25 AM
billydee203
Jan 18, 2016 04:02 PM
m_x
Jan 16, 2016 03:55 PM
SilverEX15
Aug 25, 2014 08:29 AM
jimnorine
Sep 9, 2008 01:31 AM
