08 Fit Auxillary plug
Old Oct 19, 2008 | 12:42 AM
IfTheFoo's Avatar
Originally Posted by CBX
The Aux In on the Fit dash really begs for a 90 degree connector, to keep it from sticking straight (duh!) out.
I bought a couple different lengths of these;
3' ft 3.5mm 1/8" Gold Right Angle Stereo Audio Cable - eBay (item 230292121690 end time Sep-29-08 18:53:17 PDT)
to connect to the audio output of my GPS receiver, which also plays mp3 music and XM Radio.
IfTheFoo; On this seemingly friendlier thread, I think I can mention I am in Yavapai County, West of Prescott. I make frequent trips to The Valley, even stopping at The Billett occasionally. Cheers!
Props, man. New here to phx but I'll check out the B - Cheers back 2ya!
But, back to topic, a 90 degree would make a lotta sense.
Old Oct 19, 2008 | 12:56 AM
CBX's Avatar
CBX
A friend in South Scottsdale has a Road King and my borrowed(?) StreetPilot, and the 90 degree cord would be perfect. Now that the temp is under 100, I can ride down to test it!
Every vehicle should have an Aux input.
I had to change the stereo in my F-250 to get one.
Come to think of it, give me a line-in, and skip the radio!
Old Oct 19, 2008 | 01:10 AM
feddup's Avatar
So is this mystery solved? Can she play her IPOD? That's the point of these forums!
Old Oct 19, 2008 | 01:17 AM
CBX's Avatar
CBX
Don' know. The OP hasn't checked back in on this thread since 9/21.
I know I could play her iPod.
Old Oct 19, 2008 | 08:28 AM
cargirl2B's Avatar
I've done just as has been suggested in this forum, but so far, no luck.
I'm going to try your suggestions again and will also call the company I bought the decal from to hear their suggestions.
I'm determined to get the mp player/iPod to work in AUX mode, so I'll keep you posted.
CarGirl
Old Oct 19, 2008 | 09:55 AM
zukered's Avatar
I also have an '08 LX, and have no problem playing my iPod through the aux jack. The cable I got wasn't fancy gold plated or anything--just got it at the dollar store!
Old Oct 19, 2008 | 10:11 AM
Maximuz's Avatar
maybe your aux post is borked. get it checked.
Old Oct 19, 2008 | 11:26 AM
cargirl2B's Avatar
Yes, I think there must be something either wrong with the AUX post or the cable itself. After lots of jiggling with the cable near the AUX jack and after hearing lots of static, I could finally hear music, but the music comes through on an erratic basis. Any movement on the iPod or on the cable around the jack creates distortion and static, and the music fades in and out.
I'll get this checked out.
Thanks.
CarGirl
Old Oct 19, 2008 | 02:40 PM
feddup's Avatar
A known weak point of ipods and any MP3 players is the actual jack that you plug the headphones into. Try another music producing device and another cable to aid in the process of elimination. It COULD BE your fit's AUX port but I personally doubt it!
Old Oct 19, 2008 | 09:20 PM
zukered's Avatar
Is your iPod using a case that covers the area around the jack? The case might be leaving enough of an opening for the normal iPod earphones to jack in, but for the aux cable, I have to either press the connector into the iPod jack really tightly, or move that part of the case away (mine's a soft silicone cover 1 or 2 mm thick).
BurntZ
May 17, 2013 09:23 AM
willitfit
Dec 26, 2008 03:14 AM
fitster
Oct 17, 2008 03:25 AM
tanger
Sep 29, 2008 05:11 AM
jman245
Jun 30, 2008 01:30 PM
