Changed Transmission Fluid -- ATF Z-1 and New Synthetic DW-1 Comparison
Old Feb 1, 2011 | 08:28 AM
Empire's Avatar
I cut my filter open at 50K and could't see anything, here is more info https://www.fitfreak.net/forums/gene...tml#post841968
Old Feb 3, 2011 | 03:45 AM
E = Mc2's Avatar
Originally Posted by lmatthew9
Book says to use 2.6 US QT when you do a change. I am just now learing a lot about being car savy. The total fluid capacity is listed at 6.18 US QT. I know the math equals out to changing less than half the actual fluid. Why is that?
Levi
Because you're only draining the fluid which accumulates in the 'pan'. Automatic transmissions have myriad routings for the fluid through the case and valve body which do not drain back when the engine is shut off. Also (and more importantly) the torque converter contains quite a bit of fluid. Most newer cars' torque converters do not have a drain plug. If you really wanted to get most of the used oil out, you'd have to separate the engine from the transmission and drain the torque converter, too.
Old Feb 3, 2011 | 07:27 PM
FattyMcGee's Avatar
Originally Posted by Shora
I usually use the trusty oil drain pan to catch most, if not all, fluids that I change in my cars.
I know that I'm making it a bigger issue than it really is and will most likely use your empty milk jug suggestion.
Do you happen to know if Honda lists the amount of fluid that needs to be replaced with a drain/ refill of the transmission?
Thanks a lot and I'll take some pics of my used transmission fluid as well since my 09 is at just under 30K miles too with 85-90% highway miles.
I keep an old 5 quart oil jug handy for these situations. To find out how much to replace i always drain it into my drain pan then poor it into the 5 quart jug and use the measurements from that to figure out how much to poor in. Ive never had a problem and it really eliminates the guesswork.
Old Feb 5, 2012 | 03:03 PM
Steve244's Avatar
For shits and giggles and the terminally OCD I've done a spreadsheet of the fill schedule and resulting percentage DW-1. This assumes some driving time between fills to mix the fluid (otherwise another drain/fill is probably just draining the good stuff).
Old Sep 27, 2013 | 01:56 PM
thc888's Avatar
Guy, the service manual says refill with 2.6 qts. Wonder 3 qts would over fill it and cause over pressured internally of the trany.
Old Sep 28, 2013 | 10:11 AM
Steve244's Avatar
It's not sealed so pressure isn't an issue. At some point the level of the fluid will start contacting moving parts. Might cause air in the fluid that would degrade its function. I don't think half a quart would do it though.
Also, varying amounts of fluid actually drain, it's not always 2.6 quarts. So have 4 on hand.
Old Sep 28, 2013 | 04:59 PM
thc888's Avatar
Thank you. Yes, I found out that it takes about 3 qts to really make it to the top of the line.
FattyMcGee
Jul 27, 2021 11:29 AM
JerryHughes
Jul 13, 2019 11:09 AM
JerryHughes
Apr 10, 2019 11:33 AM
domromer
Feb 19, 2019 06:37 PM
DaviT
May 4, 2005 04:44 PM
