Progress Auto Rear Anti-Sway bar! WITH DIY PHOTOS PAGE 5!
Old Mar 19, 2008 | 07:01 PM
  #521
1LegitFit's Avatar
I do. I'll call you when I get it next Monday. Is it a pretty straight forward instruction to install?
Old Mar 19, 2008 | 07:06 PM
  #522
yep, very easy to do. just need to have a jackstand so that
both rear wheels are completely off the ground and you can
remove the springs.
Old Mar 19, 2008 | 07:40 PM
  #523
1LegitFit's Avatar
Thanks Kenchan!
Old Mar 20, 2008 | 02:56 PM
  #524
bigtymer8700's Avatar
HELP!! put progress bar on but cant get the springs back on wat do i do?
Old Mar 20, 2008 | 03:33 PM
  #525
the bolts are in the way of the plastic covers of the springs and the springs still wont go in anyway
Old Mar 20, 2008 | 03:40 PM
  #526
GAFIT's Avatar
Make sure that you have them correct top/bottom. You can also get more travel from the suspension by pushing down on the spring perch. Make sure that one side isn't being help up because it will limit the travel of the other side.
Old Mar 20, 2008 | 03:41 PM
  #527
GAFIT's Avatar
Also make sure you have the bolts in with the heads up not threads up.
Old Mar 20, 2008 | 04:04 PM
  #528
smeister's Avatar
Look at these pics at the bottom. That's how the bolts should look like.
Honda Fit DIY and Reviews by smeister13: DIY: Install Progress Rear Swabar for Honda Fit
Old Mar 20, 2008 | 04:45 PM
  #529
thx guys already got it fixed
Old Mar 21, 2008 | 06:59 PM
  #530
alexfree05's Avatar
just installed mine today.
and the passenger side's spring makes some weird sound when there is little bump.
and the spring sit does not fit because there are 3 bolts for sway bar already. and the level of the spring sit is uneven.
Old Mar 21, 2008 | 07:20 PM
  #531
solbrothers's Avatar
yeah, you'll have to grind some bolts. im actually going to do that RIGHT now. i'll have pix shortly.
panducky also has bolts they sell, that are a different style, with a smaller head on tehm.
Old Mar 21, 2008 | 08:26 PM
  #532
alexfree05's Avatar
thanks!
do you mean to cut a little bit of the bolts?
Old Mar 21, 2008 | 08:52 PM
  #533
there's a thread in the bayarea forum. i'll look for a link. pretty simple.
Old Mar 25, 2008 | 12:02 PM
  #534
Polish's Avatar
Got mine today! Can't wait to put it in. I was going to try on my lunch break but in case something messes up I'll wait till I am home after work.
Old Mar 25, 2008 | 12:18 PM
  #535
1LegitFit's Avatar
Got mine yesterday and installed it last night. Test drove the Fit and handling def improved. My springs right now are still settling. So after it settles, handling should be tighter. I'll post my installation recommendation later that will help save time and frustration.
Old Mar 25, 2008 | 12:59 PM
  #536
usually it is the other way around after it settled. it should feel more
consistent and more dynamic. it usually starts off tight (as in brittle)
and kinda softens up (as in more natural movement).
Old Mar 28, 2008 | 03:17 PM
  #537
Y0ssar1an's Avatar
Does installation void Honda's warranty?
Hi,
Does installing one of these sway bars void Honda's warranty?
Thanks!
(NB: I searched first but failed to find an answer)
Old Mar 28, 2008 | 03:27 PM
  #538
GAFIT's Avatar
Originally Posted by Y0ssar1an
Hi,
Thanks!
According to the Magnuson Moss Act Honda can not void your warranty because of the installation of aftermarket parts. They can only choose to not repair damage that is related to the part.
In other words, it is possible that Honda could deny warranty claims on suspension components if they can prove that the Progress bar caused the factory parts to fail. They can not, for instance, deny repairing your air conditioner, power windows, transmission, etc because of the added suspension part.
Old Mar 31, 2008 | 09:15 PM
  #539
manxman's Avatar
Furthermore, the Progress Rear Anti-Sway bar absolutely cannot cause the failure of any part of the Honda Fit rear axle/suspension. Buy it, install it-- that will be the best decision that you ever made since buying your Fit.
Old Apr 1, 2008 | 08:51 AM
  #540
GAFIT's Avatar
Agreed...it would be a very far stretch to conclude that a fixed, non-moving part that doesn't touch anything except the lower spring perches caused ANY kind of extra wear.
The handling improvement was expected. What surprised me the most was the improved straight line stability. It's much more stable just rolling down the highway now.
