Quote:
Originally Posted by Mx6GT89
Its not safe at all. 14.0- 15.0 AFR's is what cars run around at cruising speeds and 1/4 throttle.
good to know. What about WOT?
To make good power and be safe in (most) NA car, 12.5-13.0 AFR's.(depending on compression ratings and timing)
Turbo cars are suppose to run 11.0-11.5 AFRs to be safe.(or you need to look into timing/pcm control) I have one
Almost any aftermarket engine (or exhaust)piece is considered a "race part."
Slightly modified, and agreed.
Honestly, I think this testpipe slowly ruined my motor. Recently, my car has been giving me shit MPG. 29-32MPG. If it sits at idle for a while when its hot out itll puff smoke if I rev it. Its only when I rev it though. And it clears right away. However, a new car should not do this.
And its blue smoke, which is burnt oil.
Sounds like piston rings to me...
However, I MAY be ok due to me not having a header. I do remember headers with large runners are what make the Fit lean.
Disagree. Header will not make that drastic a difference on a N/A car with such a small amount of displacement. The cat-delete/test-pipe will make more if a difference than a header when matching the two up against one another (as far a cfm flow is concerned).
I hope you don't mind, but i put a couple of
MY opinionated additions into your post in
red.
On a side note: Mx6GT89 you may want to do a compression test on your car to be on the safe side.
As always this is just my $0.02
