Mileage reports: Manual transmission (5MT)
Old May 10, 2008 | 10:41 AM
  #541
pb and h's Avatar
the name is Shawn and sahwn on honda-tech.com.
I just changed the oil and used 0w20........that shit is like water!
I pulled out the dipstick to check the oil and it just dripped off the dip stick like water, I had to do it twice to make sure I didn't imagine it. I guess I will see how long this stuff lasts. I will check it often since I am worried about it being so runny and thin.
Old May 10, 2008 | 11:34 AM
  #542
cojaro's Avatar
So the car is still amazing me. My last tank I still drove my usual 10%highway/90%city and I still got an amazing 36.5mpg! The only think different I've done for the last two tanks is shift into 5th gear more often. The warmer weather may be a factor too, but either way I am not complaining.
Old May 10, 2008 | 08:16 PM
  #543
JBElliott's Avatar
Here's the chart for my Fit off of CleanMPG.com:
now, if we fit a straight line to the mpg as a function of time and then extrapolate . . . The start of the chart is that start of the driving for the Fit. I bought it with about 20 miles on the odometer and have been the sole drive (well, except for my wife a few days).
From what I understand about how things work on that site, one extra 0.1 mpg and I'm an expert hypermiler! I can't wait!
Old May 11, 2008 | 01:56 PM
  #544
RichXKU's Avatar
Nice Work! Here's my chart too. Last tank was 50.1 MPG over 460 miles
Old May 12, 2008 | 06:48 PM
  #545
michaelpotter's Avatar
Best tank ever 745 km = 462 miles
Old May 12, 2008 | 07:37 PM
  #546
Giggles's Avatar
That's incredible! My best tank full till light was 482km (301.3 miles).
Old May 16, 2008 | 03:23 PM
  #547
JBElliott's Avatar
New update for the latest fill up:
Gallons Miles Tank's MPG
9.663 413.20 42.76105
That's six 40+ mpg tanks in a row now. As always, I filled up one click past the shut off. I did quite a bit of drafting, kept my speed under 65 mpg, but over 55 mpg, a lot of downhill in neutral gliding, some pulse and gliding and for the first time, I shut off the engine at long traffic lights. That's going to take a little getting used to doing.
Just adding up the total gallons and miles gives: 199.581 gallons over 7517.3 equals 37.66541 miles per gallon.
Finding the mean mpg of the fillups listed above gives 37.62503 mpg with an error on the mean of 0.6028064.
Either way it looks like the lifetime average for my Fit is 37.6+-0.6 mpg.
My CleanMPG chart is looking nicer all the time:
But it's getting hot here and using the A/C will be necessary. I avoided any A/C use on the above tank because the first half of the tank indicated I'd set a new record, so I managed to deal with the heat. But with triple digit temperatures coming up, I'll be turning on the A/C during the drive home.
Old May 16, 2008 | 04:49 PM
  #548
pcs0snq's Avatar
Can you say your eco gains are from info on this site in this area?
Old May 16, 2008 | 04:54 PM
  #549
pb and h's Avatar
I know I can say that. Most of the info has come from Paul's posts. I have no Scan Gauge FTL
Before I started lurking here I would get 35-39mpg.........driving like a jackass most of the time.
Old May 17, 2008 | 06:34 PM
  #550
pcs0snq's Avatar
Thought I was into a great run but must of pumped a little too much.
Made it 423 miles before the E light
Filled at 427 miles
9.645 gal
87 Octane Costco gas @ $3.80/ gal
44.23mpg
My commute now is on I-95 and no longer the Fla Turnpike Being on 4 lanes and not 2 has made it easier to go slower and lost of 18 wheelers or other large trucks to 1 sec draft.
Still toughing it out with no A/C
I have posted this many times but to new users me stuff includes
1 sec drafting always under 65 unless drafting a rig that will go as much as 70.
Lots of coasting in 5th and 4th and also neutral. Rarely use my Brakes
Med to easy start.
Car is 100% stock as far as Eco with tires at 45psi
That's it for my hypermilling.
Old May 18, 2008 | 07:56 AM
  #551
pb and h's Avatar
I would have been cussing and kicking the gas pump.
I remember about two months a go I was waiting for the auto cut off and all I got was damn gas spewing out! I guess that is a chance you take with the cheap gas stations
Old May 18, 2008 | 08:59 AM
  #552
pcs0snq's Avatar
Guess you have never used Costco gas. They maintain there pumps better than any station I have been to. They always have a man walking around making sure there are no issues and the gas works fine.
I sold my 1998 Suburban in Feb and it drank Costco 87 for 10 years and 258k miles. Never had any eng work and it ran as well when I sold it as when new.
Cheap nope
A good deal YEP
Old May 18, 2008 | 12:15 PM
  #553
WGE's Avatar
WGE
We just got our first tank over 40 mpg after a fill this morning. Same gas station and exactly the same pump, filled to first cutoff. For 354 miles and 8.666 gallons (US) the calculation is 40.85 mpg, almost 41. We have less than 2000 miles on the Fit, so maybe it will increase a little more in the future. Maybe I can shoot for 45! This is a base Fit with manual transmission.
Old May 18, 2008 | 12:42 PM
  #554
pcs0snq's Avatar
Gret job WGE!
You can record this on the CleanMPG suite.
Old May 18, 2008 | 01:11 PM
  #555
solbrothers's Avatar
wow. just got back from a 41mpg trip. a nice 13 mile drive. some stops and some hills. not bad.
Old May 18, 2008 | 03:25 PM
  #556
stendzme's Avatar
Talking
Okay - first real test of mileage since I picked up the car on May 6.
400km of driving (300 mile?), including a mix of stop n go in downtown toronto and some highway. Definitely not babying the car as I'm still having fun "breaking it in".
Only used 25 L of gas. I was quite shocked when the pump stopped so low as i'm used to filling up the truck I just got rid of - same amount of driving would have been about 60L!
So mileage was 6.25L/100Km, or 37.6 MPG for you US folks.
SWEET!
Old May 19, 2008 | 08:22 AM
  #557
pb and h's Avatar
467.5 miles(the gas light did not come on) and used 8.5 gallons to fill the tank @ $3.59 a gallon = 55mpg
The FIT is the SHIT!
Old May 19, 2008 | 09:50 PM
  #558
HEMI-Fit's Avatar
Damn, you guys are doing great! All these great #'s are killin' me, but I just don't drive enough to get the big mileage. Round trip is right at 10mi, either stop-n-go on the highway or stoplight-to-stoplight on the side streets. Half the trip is warming up, and half the time is sitting still. This will be my first full tank of forced auto stopping, about the only hypermile technique that MIGHT make a difference for me. At least I'm beating the EPA city estimate so far...
HF
Old May 20, 2008 | 10:46 AM
  #559
p nut's Avatar
Hey, man, neutal coasting actually uses more gas than if you put it into gear and then coast, which uses virtually no gas.
Also, can you guys start posting the percentage of time spent on the highway vs. city? When I record my MPG on my spreadsheet, I always put highway/city percentage (roughly estimated, of course). Thanks.
Oh, those that are getting high 40's and 50's, that is INCREDIBLE! Even Honda stated 28/34 (of course YMMV, but I never thought be that much).
Old May 20, 2008 | 11:21 AM
  #560
pb and h's Avatar
DAMNIT!
what's his nuts just beat my average mpg and achieved 59.1mpg! :
CleanMPG, - Garage An authoritative source on fuel economy and hypermiling
