Quote:
Originally Posted by eldaino
hmmm...just seems weird that it would be that way, i've never heard of the j's or mugen setups needing negative camber....i'm sure they can benefit from it in the same way, but i've never heard of anyone complaining of unstable-ness. would this be the case with them too? or is this just something thats for the tr1 dampers?
spoonek4 has test driven the car right after the install so alignment wasn't done. I think he was going through an off camber turn while the Fit has no camber then he felt unstable
Put it this way, you don't necessarily need the camber bolts. You would want to consider to use them if you want to get the full potential of the suspension and full traction to your tires.
