Illusive VS Sugarphreak
Old Sep 4, 2008 | 12:12 AM
  #161
YeeFit's Avatar
Originally Posted by Mr_ET
we can do yours and mine at the mustang shop and Adam another day as long as you guys pay the dyno fees for mine I'm good and he will still have a baseline to compare too.
Good/bad idea Adam?
Just found out that the wedding isn't actually til the weekend after! So i'm still in for this sunday. I don't think I have time to do a tune, so just the dyno will have to suffice for now.
Hey ET, since i'm running a bit rich... if I up'd the boost to say 7-8psi would that mean I would be less rich?
Old Sep 4, 2008 | 12:33 AM
  #162
Sugarphreak's Avatar
Push My Button
haha, and of course the side affect of gaining some more whp
Old Sep 4, 2008 | 08:24 AM
  #163
Mr_ET's Avatar
depends where you are running rich in the rpm range. If it's out of boost it won't matter.
If it's in boost it will lean it out yes but your timing won't be properly set for the new boost value. It's not a huge change but on a new engine like the Fit's we don't know the limits yet so I wouldn't chance it.
Old Sep 4, 2008 | 03:21 PM
  #164
Push My Button
I think Skunk2 ran a stable engine at 18psi.... but then it blew up at 21psi
Doesn't the Kraftwerks high boost use 10psi?
Old Sep 4, 2008 | 03:39 PM
  #165
Mr_ET's Avatar
psi's mean nothing man until you know on what turbo.
a GT42R pushing out 10psi will make a crapload more power than a GT28RS pushing the same amount of boost.
All I remember from street tuner challenge is that fit put down 145whp on 3 cylinders and they were afraid she would blow.
I think just like the older d series engines, 200whp will be the rough limit with a good tune.
Old Sep 4, 2008 | 03:54 PM
  #166
YeeFit's Avatar
I don't know much about the emanage and MAP tuning, but I got a reply from Ben at AJ-R about how to increase/decrease fuel. He mentioned that if I wanted to increase the fuel I would need to hook the emanage directly to the injector harnesses.
Fortunately I don't need to increase fuel, and he said to decrease the fuel I would just need to adjust the MAP. (I don't know why he has MAP in all caps, but I am assuming that I could just fine tune the 6psi map that came with the kit with my laptop and the software). Unless MAP has another meaning that I am not aware of.
Ben is going to replace the wastegate that he blew and then hopefully get onto a dyno within the next couple weeks. I think once he releases that new map I will get a dyno tune done.
Old Sep 4, 2008 | 04:02 PM
  #167
Mr_ET's Avatar
Ben was talking about the MAP sensor that is near the throttle body on the car. I don't know how it could be adjusted though I think it's just voltage going through so something would need to tap into it and tell it it's not getting what it thinks it's getting...
Adjusting your fuel map is a good start but you also always need to look at timing for boost applications so you don't end up with ping and knock.
A safe basemap can be created that will probably retard timing a bit more than needed and fuel usually is a bit rich but that keeps the engine alive. The only real way to fine tune after is by using a dyno and getting it tuned by someone that knows that to look and listen for.
Old Sep 5, 2008 | 10:14 AM
  #168
Mr_ET's Avatar
So Adam, Nick, are we still good for Sunday? I will be expecting you guys to be at the Mustange Shop at 2pm so we can get our dyno on!
Jon if you want to drop by you're more than welcome to. We'll probably be there about 2 hours total to dyno all 3 cars.
Old Sep 5, 2008 | 10:20 AM
  #169
Push My Button
Sounds good!
Old Sep 5, 2008 | 03:40 PM
  #170
YeeFit's Avatar
Sounds good!
ditto.. how much is this gonna cost again? 60 for the dyno, and 1/2 of yours? so 90 for me and nick?
Old Sep 5, 2008 | 06:31 PM
  #171
Mr_ET's Avatar
Yes sir
Old Sep 5, 2008 | 06:41 PM
  #172
JDMish's Avatar
Sunday? I'll try and make it!
Old Sep 5, 2008 | 08:17 PM
  #173
Mr_ET's Avatar
Sunday themustang shop, 2pm be there or be square!
omg that was horrible... see people this is what happens when both my kids get sick and I get no sleep for 2 straight days.
Old Sep 5, 2008 | 09:09 PM
  #174
Push My Button
Sick kids, does not sound like fun!
Old Sep 7, 2008 | 11:55 AM
  #175
Push My Button
I am probably just going to run the wheels I have on, don't worry about swapping shoes Adam!
Old Sep 7, 2008 | 03:08 PM
  #176
Mr_ET's Avatar
predictions
Adam 137whp
Me 83whp
Nick 96.2whp
See you guys soon
Old Sep 7, 2008 | 06:03 PM
  #177
Fitcapo's Avatar
so you guys are going to have a stock fit a turbo fit and a sugarphreak fit?
Old Sep 7, 2008 | 10:05 PM
  #178
Push My Button
So anyway.... can Honda West check my AF?
Old Sep 8, 2008 | 12:27 PM
  #179
JDMish's Avatar
I should get one in for testing purposes for the shop.
but no, we can test it here.
Old Sep 8, 2008 | 12:34 PM
  #180
YeeFit's Avatar
predictions
Adam 137whp
Me 83whp
Nick 96.2whp
See you guys soon
I almost made 20 more whp than predicted! woot woot!
Do you guys remember what my best run was? I only ended up getting data from 1 of my passes.. I think Toma accidently printed it out twice.. the only sheet I have says 154.9whp 146.3tq.
So I spoke to my buddy Allan. He used to work at speedtech and now works at Silverhill Acura. He is really familiar with Greddy stuff and he wants to tune my car for me. He's the one who installed the greddy turbo kit into the 08 SI in town.. and a few others..
Hey ET.. do you think once I get the new map from Ben, Toma would be cool if I used the Dyno to tune, but had Allan do it over him? What would the cost be if I did that? $100/hr?
