Ignition Light Ring DIY
Old Oct 18, 2008 | 06:56 PM
  #41
JDM_DOHC_SiR's Avatar
Lightbulb
Originally Posted by niko3257
it shouldn't matter what fuse slot you choose as long as it's constantly
hot. meaning 12V positive even when car is off.
also make sure all your connections are good.
Yep....just make sure you double check the connections...
Old Oct 18, 2008 | 08:03 PM
  #42
aenokea's Avatar
I went to watch some football and relax a little. (My team lost though which made me more irritated) Afterwards i rechecked all my connections. I thought maybe those quick splice connectors were no good so I actually cut the wires and spliced them all with butt connectors. Im sure Im getting 12v constant at the fuse because its blinking red right now with the doors locked. Is it possible that I have a bad unit? If my connections were no good, it wouldnt be blinking red right now right? Any other suggestions?
Thanks!
Old Oct 18, 2008 | 08:19 PM
  #43
Lightbulb
Sounds like the Blue wire.. needs to be double checked... that is the one that activates the Blue LED... what color wire do you have this hooked up to in the car..?
Here is the colors and wires just incase
Red is 12v constant
Black is ground
Yellow is switched by ignition.
we will be hooking this one up to
gray wire.
Blue is door lock unlock
the brown wire with silver spots. ( this wire is very important as it needs to see a - signal in order to work properly )
Old Oct 18, 2008 | 09:51 PM
  #44
aenokea's Avatar
I'll give that wire another check Dave. But isnt this the same wire that gives signal to blink red when its locked? Im almost certain thats the wire its connected to now. But I'll go outside and check it.
Old Oct 18, 2008 | 09:54 PM
  #45
I`ll be waiting
Old Oct 18, 2008 | 10:24 PM
  #46
aenokea's Avatar
I just checked and Im connected to the brown wire with silver dots. Its the wire in the small green connector on the left side. I dont know what else to check. Id be alright if the red light didnt work and the blue light worked. I bought this because the keyhole is hard to see.
Old Oct 18, 2008 | 10:26 PM
  #47
I got you covered... PM me
Old Oct 19, 2008 | 01:28 AM
  #48
Rippo's Avatar
what's the name of that ring and how much? and where did you get it? thanks
Old Oct 19, 2008 | 02:16 AM
  #49
PM me....
Old Oct 22, 2008 | 08:17 PM
  #50
Bump this back up top for good info..
Old Oct 22, 2008 | 09:22 PM
  #51
theloxmyth's Avatar
Fit Gadget Freak
Thanks for the 'heads-up' on the install for my 2008 base LED ignition light ring!
See installation advice here:
https://www.fitfreak.net/forums/1st-...ase-model.html
Old Oct 22, 2008 | 09:46 PM
  #52
Thumbs up
Great job with the DIY now the GE & GD guys now how too install this
Old Oct 24, 2008 | 08:42 PM
  #53
Bump for good info..
Old Oct 27, 2008 | 06:42 PM
  #54
2009BRENTWOODFIT's Avatar
Ignition Light
Great post with excellent pictures. I'd like to make the install but I can't find the light. Do you have a source?
Thanks!
Old Oct 27, 2008 | 07:10 PM
  #55
Thanks!
I can get them... PM me.... for details
Old Oct 29, 2008 | 10:24 PM
  #56
aenokea's Avatar
Just finished installing my keyring light and its all good now! Thanks JDM!!
Old Oct 29, 2008 | 10:37 PM
  #57
09 Fit's Avatar
Thanks JDM and niko!
Installation was EZ and turned out GREAT
Old Oct 29, 2008 | 11:10 PM
  #58
theloxmyth's Avatar
Fit Gadget Freak
Question What did you do to expose your LED so much?
How is your LED exposure so large? Mine is tiny compared to yours!
Is it the differences between the 08 and 09, or did you enlarge your bezel cut-out?
so here are a few pics when it's on.
blue is when door(s) unlocked
red is when car is locked
flashes red also like a security feature.
i can take video but i don't know how to post it.
but i did find this on the web thanks to JDM
http://www.world-1.jp/20071129235128.3gp
also have this info for you guys
Translated version of http://www.world-1.jp/keyring.html
Translated version of http://minkara.carview.co.jp/userid/257175/car/150134/424657/note.aspx
thanks again Dave
DIY done
Old Oct 30, 2008 | 12:01 AM
  #59
niko3257's Avatar
FitFreak GE8 DIY Guy
thanks
glad to see you got one.
i don't even know how long i had mine in
any more but i love it.
Old Oct 30, 2008 | 12:06 AM
  #60
niko3257's Avatar
sorry to hear that.
your benzel def has to be smaller.
I didn't do anything to my benzel.
09's must have a bigger hole.
just get a sharp blade and cut some
out. thats the best thing i can think of
for now.
keep us posted on what you did though.
