KraftWerks Supercharger Kit Info v4.0
Old Jan 10, 2009 | 02:22 AM
  #161
usmc0341's Avatar
Originally Posted by OJRKraftWerks
I am sure AT kit owners can come on here and assure everyone that the AT Base kit is a great driving package, that really adds what the Fit AT needed.
-Oscar Jr.
I can definitely attest to that notion. The only reason I even got back into the tuning scene with the KW kit was because my Fit practically died on the hills going from LA to Vegas...and it was just my wife and I (no we're not fat@sses).
Before I had the Fit I owned a Ridgeline that did a great job even with it's undersized v6. Obviously switching from an RL to a Fit meant a great loss in torque, and that's exactly the thing I missed the most. Now with the base kit alone I've gained a 50% increase in torque...
Also I totally agree with Wave. My car doesn't get a second look for a reason - it's practically bone stock. But when I merge onto the freeway and floor the gas, other drivers do get caught off guard. People in SoCal know interstate 10 has a decent hill around the 57 interchange near CalPoly Pomona. Well even without building up at the base of it I was able to scream over 100 mph before the peak of the hill, even shocking a brand new Mustang GT along the way.
We all know this kit and any other mild build-up on the Fit doesn't compare to a good deal of the tuner cars out there. But for what it's worth, the KW kit provides some much needed power that this car has been needing right from the start.
Old Jan 10, 2009 | 01:38 PM
  #162
xorbe's Avatar
Everyone, there was no plan ever for highboost a/t -- as a long time thread lurker, I don't know where that idea came from. However, Hondata for a/t was fuzzy. Also, kits for 2009, I think JDM Chris mentioned that the under hood space was even less for 2009, and wasn't sure if KW would tackle that.
Originally Posted by usmc0341
... my Fit practically died on the hills going from LA to Vegas ...
Dude I did that drive from the Bay Area, and I had my foot buried into the floor on those hills! That was a long drive.
That is the most annoying thing. In my sporty car, people make room for me. But in the VR6 Jetta, people don't realize it's a quick vehicle and often cut me off without looking it seems.
Old Jan 12, 2009 | 10:05 PM
  #163
eldaino's Avatar
wave and usmc: thanks for the nice posts. suprising people and getting people to wonder why they can't shake that jelly bean shaped subcompact is exactly the kind of effect i'd like to make.
i don't want to show up at a meet and start talking about what other hondas i can take down, just want to show be different and have a car that doesn't feel overwhelmed all the time. in all honesty, if the car can feel like my wifey's 08 beetle (2900lbs, 170lb-ft tq) and build up speed just as effortless, even with people in the car, i'm game because thats all i want.
oscar: thanks for the clarifications. one question though...i remember with the old kit, the numbers jumped up significantly once the upgraded injectors were thrown into the mix, at least when compared to the base kit on stock injectors.
do you guys expect the same type of effect with the a/t kit?
Old Jan 16, 2009 | 04:13 PM
  #164
revd34's Avatar
i can't wait for the numbers when the high boost kit comes out and reflash with injectors. i can see this making 180hp (which is good enough for me)
Old Jan 16, 2009 | 04:51 PM
  #165
eldaino's Avatar
see this what gets me.
kraftwerks had a BUILT l15 running high boost and it made over 190 whp, but they claimed it was not suited for daily driving.
we have yet to see what base kit+ injectors will look like, but i would imagine somewhere in the 140-150 range, with hondata slightly higher.
so basically that leaves a small window before it becomes 'undrivable' and it makes one wonder how much of an improvement the 10psi kit will be over the hondata.
unless ofcourse the jacksons are just being conservative, (as i believe they have a 'if its not stock-like/reliable, its not daily driveable' mentality, which i share.), and hence the original info with regards to their built fit.
Old Jan 16, 2009 | 05:22 PM
  #166
artieman's Avatar
Power output with boost is linear. I doubt it will make 160hp with the high boost kit.
Old Jan 16, 2009 | 05:38 PM
  #167
trancedsailor's Avatar
I really can't wait for more info on highboost kit
Old Jan 16, 2009 | 05:54 PM
  #168
eldaino's Avatar
you think so?
considering the old, less efficient kit with upgraded injectors made 140whp, you don't think that with 5 more psi of boost it will yield anymore? and thats before hondata, or taking into consideration what the newer kits power improvement carries...
Old Jan 16, 2009 | 06:47 PM
  #169
JDMchris.com's Avatar
I run THIS
The old highboost kit was 160 on a bonestock fit.
Old Jan 16, 2009 | 07:44 PM
  #170
revd34's Avatar
it was making 144hp with base kit and the old injectors upgrade package and full exhaust.
i'm about to buy one soon!!! i finally saved enough!!!
Old Jan 16, 2009 | 07:45 PM
  #171
revd34's Avatar
bonestock??? with no exhaust??? i really can't wait to see what this kit can really do
Old Jan 16, 2009 | 08:31 PM
  #172
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
cant we all...
Old Jan 16, 2009 | 09:51 PM
  #173
It will come out eventually. I'm glad they're taking their time.
Old Jan 16, 2009 | 09:52 PM
  #174
artieman's Avatar
ummm?
Kraftwerks USA Dyno Results
118hp at the wheels and you think its going to suddenly make 160 with another 5psi?
i will believe it when i see it
Old Jan 16, 2009 | 10:08 PM
  #175
I'd be happy with 140whp. From there you can get 200hp with bolt-ons and some internals
Old Jan 16, 2009 | 10:14 PM
  #176
artieman's Avatar
Not likely....with a turbo you could hit 200whp....it has already been done.
https://www.fitfreak.net/forums/fit-...yno-graph.html
didnt manage to hit 200whp with fully built motor and the s/c spinning above max rpm limit.
200hp is the limit of the c15 series rotrex based on flow rate....kraftwerks had that s/c maxxed on the track car
http://www.forcedairperformance.com/...Range_V4.0.pdf
also if you dont want to wait for the stage2 kit from kraftwerks and have someone in japan that can purchase and ship things to you.
get this http://www.power-enterprise.co.jp/ro...fit_stage2.pdf stage 2 rotrex kit is already available there from power enterprise...http://power-enterprise.co.jp/rotrex/rotrex_fit.html
Old Jan 16, 2009 | 10:47 PM
  #177
artieman's Avatar
Looks like you can also purchase the kit here in the usa
POWER ENTERPRISE USA. Leading Race Parts Design & Manufacturing Company in Japan. 100% Made In Japan
click on distributors
Old Jan 16, 2009 | 10:56 PM
  #178
I run THIS
get this http://www.power-enterprise.co.jp/ro...fit_stage2.pdf stage 2 rotrex kit is already available there from power enterprise...パワーエンタープライズ ROTREX FIT
I would stay away from power enterprise. On their Xb kits their customers were complaining of the SC,s seizing on them.... Why would they Seize? Because they mounted the Rotrex INCORRECTLY when they engineered their kit. If their engineering on all their products are like this then its a good idea to stay away.
BTW I believe the KWTA FIT IS OVER 200WHP now.
Old Jan 16, 2009 | 11:00 PM
  #179
artieman's Avatar
compare the mounting brakets on the rotrex kit from power enterprise to kraftwerks. exact same....i would buy from power enterprise before i would ever get ripped from krapwerks. power enterprise is on a whole different level from krapwerks....also the kit on my xb with 108k miles never had a problem. the kid who bought my xb is still driving it to this day without issue.
Old Jan 16, 2009 | 11:10 PM
  #180
jeez a little harsh to call them krapwerks, don't you think? You don't own a KWSC, you've probably never seen/heard/experienced a KWSC, don't talk shit about it
