Hondata
Old Aug 27, 2019 | 08:28 PM
Jonnyc's Avatar
Hondata
Any hondata users out there?
Old Aug 28, 2019 | 10:07 AM
evilchargerfan's Avatar
devmail is, I believe
https://www.fitfreak.net/forums/fit-...rey-goose.html
Old Aug 28, 2019 | 08:15 PM
Baldwin Nguyen's Avatar
I got one. Planning on getting it tuned eventually, probably by Bisimoto or Church Automotives.
Old Aug 28, 2019 | 08:40 PM
Jonnyc's Avatar
Could you tell me how many base maps or mods are available for flash
Old Aug 28, 2019 | 09:23 PM
Not much if you're driving an AT like me.
Old Aug 28, 2019 | 09:48 PM
Jonnyc's Avatar
I'm driving a mt and it doesn't show any difference, so is it still worth the money? How would it or does it make the i/h/e mach up and work in harmony
Old Aug 28, 2019 | 10:00 PM
Well they say your bolt ons aren't at full potential unless you get it tuned. The base maps are whatever but once you get a proper map tuned by a tuner, you'll notice a difference. Some of the Fit members I've talked to that have had their cars tuned say it definitely makes a difference.
Old Aug 28, 2019 | 10:13 PM
Jonnyc's Avatar
So does this mean the purchase of the hondata and then purchase of dyno time? And thank you for your responses
Old Aug 29, 2019 | 09:40 AM
you can technically skip the custom tune and just live with the base maps
of course, those maps are no where near as good as getting a custom tune
Old Aug 29, 2019 | 11:24 AM
Jonnyc's Avatar
Ok thank you, I think I will go that rout(custom tune)
Old Aug 29, 2019 | 04:10 PM
GAFIT's Avatar
I'm running a Hondata in mine. You basically either need to be able to self tune or get a custom tune.
The Hondata by itself doesn't add any power and neither will I/H/E mods. You need the mods AND a tune using the Hondata.
Think of the Hondata as a way to open up your factory ECU.
Other models, like the new Civic Si's, are way, way more supported and there's tons of built in tunes that you can try. For our unloved and forgotten GD Fit, there's just a few tunes available based on a handful of cars they tuned a long time ago.
Old Aug 29, 2019 | 04:17 PM
Jonnyc's Avatar
Ok thank you for clarifying that for me,looks like i will be doing both
Old Aug 29, 2019 | 05:51 PM
Jonnyc's Avatar
GAFIT,hows your tune working out for you?
Old Aug 29, 2019 | 09:11 PM
GAFIT's Avatar
So far I'm only using the Hondata to correct an idle issue with the aftermarket cam I installed and bump up the rev limiter a bit. Not a custom tune...just me tinkering with it.
Waiting till I have more time to dive into the car for serious mods before hitting the dyno and getting it dialed in.
I can tell you that, from playing with the Hondata software, you can make any/all necessary changes. Just need a decent tuner and dyno time.
Jonnyc
Arizona Community
Oct 17, 2019 05:53 PM
Myxalplyx
May 4, 2016 10:56 AM
euphoricminded
Oct 2, 2014 09:42 AM
bryzem
Aug 22, 2014 04:22 PM
Daemione
Sep 17, 2010 02:55 AM
