Ticking at idle
Old Feb 17, 2009 | 10:26 PM
  #41
polaski's Avatar
Originally Posted by mahout
It is entirely normal for valve clearance to increase when the temperature is in single digits. The book calls for clearances to aset at less than 100 F (38C). It doesn't say but we were always instructed that the temp should not be less than 68 F (20C). Obviously, if the temperature of the valve system is less than 68F the clearance increases enough to hear tapping. However, that ta[pping should go away as the engine comes to operating temperature. The longer that takes the longer the tapping. As long as you don't thrash the engine you're OK. Thr reason for setting at 68 to 100F is because that insures the proper clearances at the realoperating valve train temp - somewhere in the 200 to 280 f range.
Out of curiosity, Suzuki has automatic valve clearances by an innovative floating bucket system so valve adjustment is unnessary even though the 1300 will rev to 13,000 rpm.. Wonder why Honda doesn;'t do that.
Is that similar to hydraulic lifters? I know those get really loud on startup when they start to get leaky seals. Also if the valve springs aren't stout (read: fast) enough they'll actually overfill and prevent the valves from closing all the way.
Old Feb 18, 2009 | 09:56 AM
  #42
mahout's Avatar
Yes, the Suzuki valves are hydraulic just not quite the same parts as Detroit's. When hydraulic valves leak, Oldsmobile or Suzuki, the clearance increases and you get valve rapping.
Old Apr 11, 2011 | 03:46 PM
  #43
Fit_Dr's Avatar
Sorry to bump this but it's related. My 08 had 96xxx mi and had been ticking for some time. It also had an off-idle, small hesitation that felt a little like clutch slip. I had the valves adjusted and the ticking and the hesitation went away. Now, with 99xxx mi and the ticking is as bad as ever though the hesitation isn't. Valves out again or something else? TIA
Edit: I should add that the car runs fine and still gets its usual gas mileage, 36-37 mpg. It has started using a bit of oil, maybe a quart between OCIs.
Old Apr 11, 2011 | 03:53 PM
  #44
artieman's Avatar
im at 94k and having the same issues....im constantly having to re-adjust the valves to keep them from ticking...these motors are roller rocker so it makes no sense that they need to be constantly adjusted....ive never had these issues with any of the k series motors i have worked on over the years. i work in a shop building and tuning motors.
Old Apr 12, 2011 | 03:53 PM
  #45
Fit_Dr's Avatar
No one have any ideas, huh?
I asked the service manager at my dealership to look into it. Wonder if it'd require a new valvetrain to be worry-free again.
Old May 11, 2011 | 05:15 PM
  #46
Fit_Dr's Avatar
So I finally got around to bringing the car back in to the dealership. They kept the car overnight and said all the valves were in spec from when I recently had them adjusted (again, after two days of silence it started making the same noise). Service manager tells me the tech thought it was piston slap and it may or may not get worse. They would have to replace the motor to make it go away .
So not being an idiot, I'll take the car home and use a block stethoscope to see if I can pinpoint the location of the ticking. BTW, I rarely exceed even 4000 rpm.
Old May 11, 2011 | 06:33 PM
  #47
willy65000's Avatar
I regularly take mine past 4000rpms just like the other five Honda's I've owned.
Old May 11, 2011 | 06:37 PM
  #48
DiamondStarMonsters's Avatar
I probably pass 4k rpm almost every time I run through 1st gear. So like a dozen times a day at least. Granted it's often gradual or linear acceleration, and not launching it all the time. This is a Honda, they want to wind out to red line every so often.
Old May 12, 2011 | 06:30 AM
  #49
Fit_Dr's Avatar
I use this car as my daily commuter, about 70 miles a day. My purpose for it is reliable, high gas mileage transportation that can occasionally haul some stuff. At this job it excels. It is far too slow and underpowered for me to try and enjoy wringing out the engine. For that I have a 400whp STI.
I'll report back on the ticking when I have more info for anyone that cares.
Old May 12, 2011 | 11:52 AM
  #50
The Fit is my DD also. My other car is a 2.0L meth junky with a 65lb/min turbo hanging off it.
Old May 22, 2011 | 09:34 PM
  #51
Fit_Dr's Avatar
It was a bad spark plug.
frank438
Jul 12, 2016 11:14 AM
allTRACway
Mar 11, 2016 04:06 PM
2012FitFan
Nov 11, 2015 07:51 PM
g fit
May 12, 2014 07:06 PM
der Mond
Jul 3, 2011 09:29 AM
