Fit head light switch...
Old Jul 1, 2010 | 09:20 PM
hifocused's Avatar
So I had to order a new headlight switch, according to the dealer. They also said there might be a recall... as it's common? The highbeams work but not the regular ones.
Old Jul 3, 2010 | 11:23 PM
mxl180's Avatar
Check out my thread on this issue. So it's not the SWITCH, but the connector to the switch.
https://www.fitfreak.net/forums/1st-...esnt-turn.html
Old Jul 11, 2010 | 07:36 PM
hifocused's Avatar
I got it fixed... At the dealer ship they said save all the parts if there's a recall. I could be reimbursed they changed the headlight switch and something to do with a 2002 civic light recall. It cost 200.
Old Jul 22, 2010 | 12:48 AM
GreekHondaJazz's Avatar
ok here i go again. most of the problems that people are dealing with with their honda fit's, i have had. the high beams work but the low beams don't. well i got news for you. its not the switch noir is it the connector to the switch. its the wire that runs from the battery to the one metal bit on the switch. after alot of use of either flickering your headlights cause you think it makes the guy in front of you drive faster or just cause you have parkinsons (if you do im sorry), the wire melts and burns.
Gregg
Aug 8, 2017 04:24 PM
jayd
Feb 19, 2016 03:26 AM
Retroactivity
Oct 13, 2011 10:38 PM
StormSurfer
Jul 25, 2011 02:05 PM
omygod711
Feb 24, 2011 08:59 PM
