how to disable seatbelt noise or beep
Old Jul 14, 2011 | 04:27 PM
  #41
spreadhead's Avatar
Just buckle the seat belt before you sit down. Then sit on the buckled seat belt. Problem solved. If you have an accident, the airbag may save you (if it doesn't kill you). And hey, if you you do die because of no seat belt on, at least you will be comfortable, if you are only severly injured, not so much.
Old Jul 14, 2011 | 04:36 PM
  #42
mahout's Avatar
Damn. I knew somebody was going to 'solve' his dilemma that he wasn't smart enough to figure out on his own. At least there may be retribution: had you considered that some smart butt lawyer fingers you if he is even injured because he was sitting on a buckled seat belt and sues you?
In this trigger happy and down sided legal market that is a distinct possibility.
Here's your sign.
PS not having your seat belt buckled can impact you harder with the airbag. You'll be flying forward right into the exploding bag at close range. Some tests have indicated that a broken neck can result. Might be hard to drive from a wheelchair. No, its not a funny subject. Helping someone to hurt themselves isn't funny.
Old Jul 14, 2011 | 10:44 PM
  #43
kodok3ribu's Avatar
this thread is fun... i got so many new information here...
Old Feb 10, 2014 | 06:38 PM
  #44
CTCT's Avatar
You should disable your brakes too because my friend got rear-ended after hitting the brakes hard on a highway to avoid hitting a car that stopped in front of him. He could have avoided that if he just swerved around the car. So, brakes are dangerous. I know that because I know my token example is representative of every braking event for every driver. This post is sarcasm.
Old Feb 11, 2014 | 01:03 AM
  #45
xxryu139xx's Avatar
wear earplugs. at least u don't have to hear the beeping noise, or better yet, the honking of the guy in front of you you are about to hit.
Old Feb 11, 2014 | 02:55 AM
  #46
MNfit's Avatar
There is nothing more to add to this 3 year old thread then wear your seatbelt.
User1
Oct 23, 2017 09:26 PM
Soon2015FitWillBeMine
Nov 9, 2015 02:09 PM
SilverEX15
Jul 31, 2014 05:30 PM
frankgindc
Feb 19, 2008 01:00 PM
Telix
Oct 5, 2007 02:34 PM
