Throwout bearing noise?
Old Sep 23, 2023 | 12:05 PM
patmegron's Avatar
Red face Throwout bearing noise?
First post on the forums!
Whenever I shift from 1-2-3 and I let off of the clutch I hear a slight sound that goes away a second or two after.
Friend said it may be a cheap throwout bearing as he thinks the clutch was replaced not too long ago because his GD3 makes the same noise but not as noticeable.
The drive isn't affected nor is shifting aside from the noise, clutch seems to grab pretty low on the pedal and transfers power fairly well.
Picked up a Orange 09 Sport GE8 and has been a decent commuter. Cost me $5.6k CDN taxes in which seemed like a good deal compared to what I had seen in the market. I did buy it as wholesale from a dealership so some damages on the sideskirts and windshield, the interior was totally dirty but nothing bad mechanically apart from the noise.
I see a rear sway bar is a pretty good mod, i went to a aftermarket store locally and someone said I should do lowering springs alongside the RSB. Part of me thought he's upselling me on things but I kinda understand lowering the centre of gravity. Thoughts on that?
Old Sep 23, 2023 | 10:21 PM
GrE8_Fit's Avatar
Welcome to the club!
Sounds like a throwout bearing to me. But I could be wrong. A sway bar and springs are a good idea, after regular maintenance stuff like fluids and valves. Also changing the brake master cylinder to remove the delay valve is popular.
Old Sep 24, 2023 | 01:21 PM
Frenzal's Avatar
I think the delay valve is in the clutch slave cylinder, not in any brake stuff...
Old Sep 24, 2023 | 03:51 PM
GrE8_Fit's Avatar
Yes, clutch master! Duh. Thanks, man.
Tripleeights
Feb 15, 2023 02:38 AM
MyFitment
Oct 4, 2021 12:43 PM
youngmogul
Apr 11, 2021 03:49 PM
Aimee Nord
Mar 12, 2021 04:35 AM
viperpit07
Nov 8, 2015 09:52 PM
